Author Topic: one button, two switches  (Read 1744 times)
Wade
  • Last login:June 02, 2025, 11:48:57 pm
  • 80's Child
    • Wade's Gameroom
« on: May 30, 2003, 02:14:37 pm »
I finally added my trackball, but I don't want to add a separate mouse button or two.  What kind of resistor/diode/thingy do I need to add so that one button can be wired in parallel to trigger both a Keywiz switch, and a mouse button?
I'm sure this has been asked before but I couldn't come up with the right combo to find hits on the search engine.
Thanks,
Wade
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
Re:one button, two switches
« Reply #1 on: May 30, 2003, 04:00:15 pm »
I don't think you'd want a diode.... cause you DO want the key stroke and mouse click both to occur from a single button.
You'll probably better off installing a slide switch on the side of the control panel.... to switch between the button sending a keystroke or a mouse click; on GUI navigation might get screwed up (like if the keystroke generated is CTRL, Alt, or Shift).
Mucal invader, is there no end to your oozing?!
_Iz-
  • Last login:Today at 01:01:19 am
  • Time to coin up!
« Reply #2 on: May 30, 2003, 04:05:40 pm »
Why not just mount the buttons in the configuration you want, choose 2 to be used as mouse buttons and then DON'T hook those 2 up to the I-Pac/Keywiz, just connect them to the "mouse". Then program mame or what have you to accept mouse clicks instead of keystrokes for those action buttons?
SirPoonga
  • Puck'em Up
  • Last login:July 20, 2025, 03:37:24 pm
  • The Bears Still Suck!
« Reply #3 on: May 30, 2003, 04:12:54 pm »
This will work.  And if it it enough for you great :)
I wires a switch to switch player 1 buttons 1 and 2 to the mouse hack and the ipac.  I did this because I map player 1 button 1 to enter which is very useful, especially for PC games.  The majority of the time the buttons are on mouse.  I have the mouse buttons mapped in mame for that.
Here's the dpdt relay I used (part number is on it, from digikey.com).
http://www.fe.donkeyfly.com/images/dpdt.jpg
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #4 on: May 30, 2003, 04:46:08 pm »
Thanks for the suggestions guys, but I don't want to use a switch because I want my cab to stay as easy to use as possible, for people who don't know all the ins and outs of it.
Also, I was planning to use buttons 5 and 6 of player one.  Or, if I use the mouse click in the "Input (all games)" for buttons 5 and 6, will that be the only change I need to make?  I don't want to have to make changes to all the 6 button games.  I suppose this may work.  I'll try it this weekend and see how it goes.
Wade
_Iz-
  • Time to coin up!
« Reply #5 on: May 30, 2003, 05:35:38 pm »
Yes.
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #6 on: May 30, 2003, 05:38:01 pm »
Cool, I'll try that first!
vitaflo
  • Last login:January 14, 2020, 08:11:04 pm
    • ASMBLR
« Reply #7 on: May 30, 2003, 06:10:53 pm »
Let us know how it goes, I've been meaning to try the exact same thing myself.
SirPoonga
  • Puck'em Up
« Reply #8 on: May 30, 2003, 06:21:43 pm »
YEah, putting it on buttons 5 and 6 is a good idea.  Just to note.  No one has any problems with my control panel.  As I said, for mame and the majority of the time the switch is on mouse.  This covers the situations about 90% of the time.  Just a few pc games I play that need Enter as a key.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #9 on: May 30, 2003, 08:25:45 pm »
Thank you , _Iz- and Wade (and others).  I have read previous explanations of how this is done but it took another description for it to finally click.  I just wired my Player 1's 5 and 6 buttons to the mouse and directed Mame32 to handle them properly and it works wonderfully.  I am still using the keyboard for Enter.  For now.    :)
planetjay
  • Last login:April 22, 2019, 10:50:57 pm
  • Ex-Evil Admin Monkey.
    • planetjay.com
« Reply #10 on: May 31, 2003, 12:21:13 am »
If you didn't get SirPoonga's drawing... here's another view for you.
planetjay.com. Still in Chicago. Still no hurricanes!
