Author Topic: Will TopGun LCD work behind tinted glass?  (Read 3075 times)
jhabers
  • Last login:August 09, 2019, 03:29:34 pm
« on: May 10, 2008, 06:00:53 pm »
My ActLabs gun is not cooperating with my betson (doesnt handle the flash too well) and I cant get it to read the gun shot at all, thinking it may be the tinted glass. Will the top gun lcd work behind tinted glass?
Jon
dmworking247
  • Last login:July 14, 2024, 01:30:59 pm
Re: Will TopGun LCD work behind tinted glass?
« Reply #1 on: May 10, 2008, 06:07:15 pm »
The TopGun wouldn't care if your screen was behind a brick wall.
Its the sensors that the gun cares about, which are two sticks with Infrared LED's to help the gun understand its position, similar to Wii remotes.  If you mount these sticks on the outside of the glass, or the side of the cabinet (depending on how wide it is), you'll have no problem at all.
If you're asking whether to mount the LED sticks behind tinted glass thats another story, although I believe Play-Asia.com sell a more powerfull version of LEDs that could do the job?
jhabers
« Reply #2 on: May 10, 2008, 06:41:46 pm »
Yea, I was thinking of putting the LED sticks behind the glass, actually thinking of cutting small holes in the plastic bezel and putting them behind there with just the leds sticking through but behind the tinted glass
Stub
  • Last login:July 08, 2024, 10:48:14 am
  • Sensory Overload
« Reply #3 on: May 10, 2008, 07:06:23 pm »
I dont believe smoked glass will dim the IR much at all. It may cause some reflections. I just put my glass in today, I will test my two lcd topguns tonight and let you know.
styxx
  • Last login:May 20, 2008, 11:32:53 am
  • My cab is a constant WIP...
« Reply #4 on: May 15, 2008, 10:20:33 pm »
...been wondering about this as well  :dunno
Stub
  • Sensory Overload
« Reply #5 on: May 16, 2008, 02:47:18 pm »
I will get this tested this weekend. I have been lacking the second person I need to get my glass out safely.
Marak
  • Last login:September 05, 2010, 11:45:05 pm
  • "Look, she's smiling"
« Reply #6 on: May 20, 2008, 12:50:47 am »
I have had my Topgun emitters behind tinted plexi for a long time.
Works great and looks even better!
Dartful Dodger
  • Newer isn't always better.
« Reply #7 on: May 20, 2008, 01:25:21 pm »
I didn't even think of this as a potential problem.
I just assumed if it was light it would be able to go through the glass no problem.
Has anyone done this and found it to be an issue?
Marak, do you have multiple guns or just one?
Procrastination may have saved me again.
fjl
  • Pixels Rule!
« Reply #8 on: May 20, 2008, 02:09:22 pm »
far as I know, IR should not have any problem working behind tinted glass. Look at your remote and the IR sensor on your TV/VCR/DVD. Most have the IR sensor and LED behind heavily tinted plastic and those work fine. Even the Wii mote.
Marak
« Reply #9 on: June 03, 2008, 02:04:01 am »
I just have one. (For now)
