Author Topic: Is my cab too big?  (Read 2593 times)
ivwshane
    • My first mame cab! (WIP)
Is my cab too big?
« on: April 30, 2008, 07:08:49 pm »
I don't know if it's just me and I'm not used to seeing naked cabs, but is my cab too big and does it seem disproportional to anyone else? The dimensions are similar to lusids design and an mk cabinet (jakobuds) and the screen with be 27".
« Last Edit: April 30, 2008, 10:40:56 pm by ivwshane »
phishpac
  • Last login:October 15, 2009, 10:42:19 am
    • grateful arcade
Re: Is my cab too big?
« Reply #1 on: April 30, 2008, 07:25:21 pm »
Is that square you have on the 2nd picture 4 feet long?  If so, I would say the cabinet looks like it's just the right size.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: April 30, 2008, 07:27:25 pm »
I don't know if it's just me and I'm not used to seeing naked cabs but is my cab too big and does it seem disproportional to you? The dimensions are similar to lusids design and an mk cabinet (jakobuds) and the screen with be 27".
The Lusid cab is a big cab anyway.... It doesn't seem disproportionate and you're using a monitor that needs and suits a big cab. So unless you think it's too big because of not having the room to keep it, then no it looks fine.
Personally I'm not a fan of large cabs, but horses for courses... If you like it then stop worrying about it and get on with building it.
Nice looking timber by the way!
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
ivwshane
« Reply #3 on: April 30, 2008, 07:30:35 pm »
Yes, I conveniently placed it there for scale;)
Thanks for the responses, I'm about to go to the point of no return and just wanted to make sure I was on the right path.
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #4 on: April 30, 2008, 07:35:15 pm »
Will it fit in your basement ?
Working: Not Enough
Projects: Too Many
Progress: None
Jack Burton
« Reply #5 on: April 30, 2008, 08:41:41 pm »
yep, if it's based off of MK then it will be a very deep cab indeed.
Ummon
  • Trade Count: (+13)
« Reply #6 on: April 30, 2008, 09:58:57 pm »
All the plans I've looked at skirt around this question I've had for a long time. What angle is the monitor at?
Yo. Chocolate.
Stephen Hawking
ivwshane
« Reply #7 on: April 30, 2008, 10:36:48 pm »
I don't have a basement and it will be going in my garage but if I did want it in a room it would barely fit (with the doors removed).
ivwshane
« Reply #8 on: April 30, 2008, 10:37:27 pm »
50°
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #9 on: May 01, 2008, 12:14:38 am »
Is the cab already more than half erected? Is it already in its final resting place?
Fozzy, let me get this straight: you're scared of big cabs but like ivwshane's wood?  ;D
ivwshane
« Reply #10 on: May 01, 2008, 12:25:19 am »
Nope, only sides have been cut and I'm working on the monitor mounting system now. The cab will have casters on it to make moving easy.
paigeoliver
  • Awesome face!
« Reply #11 on: May 01, 2008, 03:57:45 am »
Your dimensions basically look perfect, although (before going further), but if you haven't cut all your center pieces then consider measuring your monitor frame and making the cabinet about 1/8" wider (inside) than the frame (so it just barely fits). They are stronger that way, and it will make dealing with interior doors easier later on. Since the control panel will be a bolt on job it won't change that part at all.
Zobeid
  • Last login:April 21, 2021, 10:36:32 pm
« Reply #12 on: May 01, 2008, 04:10:41 am »
Thirty inches wide. . .  That'll be a tight fit through many doorways.  You may have to take doors off their hinges to get it through.
It's a much bigger cabinet, with a much bigger monitor, than I personally would prefer, and much bigger than the one I am building.  But if big is what you want, then it does seem reasonably proportioned.
The monitor angle is the same I chose for my cabinet, incidentally.  It's space-efficient and seems like a comfortable viewing angle.
ivwshane
« Reply #13 on: May 01, 2008, 04:53:49 am »
Yeah it is bigger than I really wanted but I bought the display first without really thinking things through:o
I'm not too worried, all my doors are on the second floor of my house and there is no way in hell I'm going to carry this thing up stairs! Everything down stairs is easily accessible even if it was 40" wide:D
Have you finished your cab yet? I'd like to see how it looks in real life.
Fozzy The Bear
« Reply #14 on: May 01, 2008, 05:37:19 am »
One thing to note with it is that I hope that you are not planning to use it with any gun games at any stage. Because with the monitor sloped back at that angle it'd be far from ideal for any of the shooters where you need the monitor to be much more upright.
Best Regards,
Zobeid
« Reply #15 on: May 01, 2008, 08:04:22 am »
Not finished yet.  The cabinet shell is in the paint shop, and meanwhile I am working on the control panel.  But you can see a few construction photos.  Project thread here:
http://forum.arcadecontrols.com/index.php?topic=78150.0
Even though mine has merely a 19" LCD, the circular frame that rotates is about 24" wide -- which is to say, almost as wide as the interior of the cabinet.  It has about half inch clearance on either side.
