Author Topic: Happ Joystick Install Question - Pivot Cylinder???  (Read 2447 times)
jw2000uk
  • Last login:September 16, 2015, 06:54:52 am
« on: April 25, 2008, 04:08:03 pm »
Hi, First off thanks for such a top forum,Im in the process of making my own MAME machine.
But ive got a question.
With the Pivot Cylinder installed,my joystick wont go long enough,Without it it seems ok.
Am i doing something wrong?
Cheers
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Happ Joystick Install Question - Pivot Cylinder???
« Reply #1 on: April 25, 2008, 06:11:59 pm »
You have to push the white actuator piece up and the joystick handle down when you put on the E-clip.
Robin
Knowledge is Power
jw2000uk
« Reply #2 on: April 26, 2008, 03:02:58 am »
EDIT.
K i think ive got it,basically i needed to push the spring together,By doing what you said,Then there's just enough room for the E-Clip.This correct.
Thanks for you help m8.
« Last Edit: April 26, 2008, 03:13:47 am by jw2000uk »
