Author Topic: Xbox 360 Arcade Controller Project  (Read 3733 times)
shredso
  • Last login:January 27, 2020, 09:23:27 pm
« on: April 19, 2008, 05:45:44 pm »
Those Mad Catz arcade controllers were clearanced at Best Buy so I grabbed a couple.  Very easy to hack.  Here is the wiring and planning stage.
shredso
Re: Xbox 360 Arcade Controller Project
« Reply #1 on: April 19, 2008, 05:49:31 pm »
Finish stage
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« Reply #2 on: April 20, 2008, 04:12:42 pm »
I have one of those laying around. How much you want to do mine?  ;D
If You Are Going To Meddle At Least Listen
shredso
« Reply #3 on: April 20, 2008, 05:22:03 pm »
The solder points on the Mad Catz controller were pretty easy.  I actually screwed up a MS one by lifting a trace, this one was a thousand times easier.  Plus if you screw it up the controller only cost like $10.
« Reply #4 on: April 21, 2008, 10:20:16 am »
I'll do it for you...   ;)
Quaternion
  • Last login:May 07, 2008, 03:43:59 pm
« Reply #5 on: April 22, 2008, 12:20:55 am »
How are you attaching the top to the box after putting the vinyl on? And I didn't see a hole for the cord coming out, did you add that after your pictures? Thanks...
Fairbanks, Alaska (<-- anybody else from AK? pm me)
One (crappy but usable) desktop/laptop control panel
Williams "Smart Set" EM pin (webpage to come)
shredso
« Reply #6 on: April 22, 2008, 08:36:57 pm »
The box top is tight without any latch, but I plan on securing it better.  I have some velcro strips I was thinking of trying.  I'm not sure what you mean by vinyl, it's just painted MDF.   The cord is just hanging out the back for now, i have a grommet sleeve in my large control panel, I may do the same, still not sure.
Quaternion
« Reply #7 on: April 25, 2008, 11:57:00 pm »
Thanks. No idea why I thought you had vinyl on there, probably I was reading too many threads at once. ..
clok
  • Last login:April 03, 2018, 10:58:39 pm
  • I can play PacMan till the screen splits!
« Reply #8 on: April 29, 2008, 01:27:44 pm »
How strong is the large Stick  on the Controler you hacked? I really want a Flight stick for some Possible Flight sim type games and it appears one might be able to hack that stick into something just like you did (also had this idea), is that stick wired or wireless?
shredso
« Reply #9 on: April 29, 2008, 09:44:39 pm »
The stick I have on the mini control panel is out of a gutted MKII cab so it's plenty strong.  If you mean the stick from the original controller, it's pretty much crap.  I think the only thing this controller was good for is to hack the board personally.
