Author Topic: can you have mutiple layouts while using mala tree?  (Read 838 times)
itstonye
  • Last login:August 03, 2008, 11:09:48 pm
« on: April 16, 2008, 08:16:01 am »
I know you can change the background when in mala tree mode, but can you actually change the layout. for instance in my main menu of the mala tree i only have 5 options representing 5 emulators and a background which has high lights behind those 5 spaces. once i get to a gamelist i would like to display 10-15 games instead of only 5 as it displays now. it is kind of a pain to scroll through a huge list when your page up/down only pages 5 games at a time. if anyone has done this or knows if it can be done please post.
thnx
~Tony E.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
Re: can you have mutiple layouts while using mala tree?
« Reply #1 on: April 16, 2008, 11:31:49 am »
You select which layout you want to use for each node when editing the tree.  You can select any layout you want for any given node.  Make the layouts and gamelists first, then create your tree.
