Author Topic: VGA to Arcade monitor  (Read 15259 times)
wrighty
  • Last login:May 22, 2008, 06:48:32 pm
Re: VGA to Arcade monitor
« Reply #40 on: May 07, 2008, 02:55:54 pm »
anyone got any dealings with tthese guys? Ive been tryin for a couple of days now with no reply.
grantspain
« Reply #41 on: May 07, 2008, 03:13:00 pm »
i know some peeps just down the road from swallow amusements,i will ask them
grantspain
« Reply #42 on: May 08, 2008, 04:46:28 pm »
you have a pm :)
wrighty
« Reply #43 on: May 11, 2008, 12:31:32 pm »
Hey, Ive got my cable. I tried to hook it all up but have a problem! I have no picture with my ArcdeVGA hooked up (the monitor stays on though and I have tinkered with the knobs at the front). this time i have connected my wires together (as traced back by my multimeter!) I also tried it with my VGA amplifier (from ultimarc) but the same. Sounds like perhaps an issue with my arcadeVGA??
What do you think?
grantspain
« Reply #44 on: May 11, 2008, 01:06:45 pm »
show me how you have connected the wires
also have you tried to turn up the screen volts on the flyback transformer
wrighty
« Reply #45 on: May 11, 2008, 03:32:57 pm »
Dunno how to turn up the volts! With the VGA amp I have connected the wires as they are labelled it in relation to the pins were on my original molex connectory. With my breakout cable I traced back each pin and looked at the ultimarc VGA diagram and marked down what wire was what. I then got my R, G, B wires and hooked them up as above, connected my horizontal and vertical sync together and the remaining wires I connected together and put in the GND.
Im 100% sure i have connected them right as with no connection on the monitor it switches off again after 2 secs. When it is connected to the ArcadeVGA it is fine. Plus using the amp makes it really simple as everything is labelled and I just put the R to R, G to G, B to B, GND to GND etc
grantspain
« Reply #46 on: May 11, 2008, 03:49:07 pm »
screen volts
if you turn this a little clockwise and you get a white screen then either your wiring is wrong/video card is not outputting a video signal or worst case scenario you have a failure with ic1 on the monitor neck card
wrighty
« Reply #47 on: May 11, 2008, 04:18:14 pm »
is it safe to turn whilst monitor is on. Incidentally should this work with the VGA amp?
grantspain
« Reply #48 on: May 11, 2008, 04:23:27 pm »
hantarex polo do not need the ultimarc amp as they work on 1v to 5 v video signal,the ultimarc amp will not damage the polo
the screen volts must be turned up a little whilst powered,use a mirror to see the affect on screen
Ummon
  • Trade Count: (+13)
« Reply #49 on: May 11, 2008, 08:42:23 pm »
tetsu96 used a JPAC with one of his candys and he said the colors were way saturated due to the in-built video amp.
« Last Edit: May 11, 2008, 08:44:12 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
wrighty
« Reply #50 on: May 14, 2008, 03:29:54 pm »
I have turned both knobs to full and the screen is white. I am sure my wiring is right as I have tested with the Multimeter. Im gonna test the card using a DVI cable through a normal monitor t see if there are any problems. ANy other ideas?
Cheers
wrighty
« Reply #51 on: May 14, 2008, 04:18:34 pm »
Just plugged it in and it works via a dvi adapter.Resolution is not right tho.
grantspain
« Reply #52 on: May 14, 2008, 04:23:55 pm »
sounds like the card is faulty on the 15khz output,give ultimarc a call/email
wrighty
« Reply #53 on: May 14, 2008, 04:56:26 pm »
If I do plug it into the VGA port to the PC monitor I get an out of range error! Suggesting the card is ok maybe?
grantspain
« Reply #54 on: May 14, 2008, 05:09:05 pm »
or no signal-best to contact andy at ultimarc
wrighty
« Reply #55 on: May 16, 2008, 02:33:11 pm »
As a test I have tried to hook my original Jamma back up to it and still no picture. Maybe my monitor is popped? Is there a way I can test my vga connector with a standard VGA card? Andy said I can send the card back for him to look at but im not sure the card is actually faulty!?
grantspain
« Reply #56 on: May 16, 2008, 07:42:19 pm »
i think i've got it,i reckon you have a switchable dual sync polo2 chassis which is set to 25khz via the jumper plug
can you take some pics of the chassis near where the yoke plugs in
wrighty
« Reply #57 on: May 16, 2008, 08:09:19 pm »
Hey good news. I have sort of got a picture. My POST screen is pretty clear but my XP boot screen is flickering. Once in windows I get a black screen.  Driver issue? Can get pics still if u want
grantspain
« Reply #58 on: May 16, 2008, 08:53:50 pm »
this is without a doubt some kind of driver/setup issue
grantspain
« Reply #59 on: May 17, 2008, 08:56:21 am »
get some good photos of the chassis
wrighty
« Reply #60 on: May 20, 2008, 11:23:47 am »
Im sure its a driver issue. Look at this thread http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=150228&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
The photos are exactly the same as what I am experiencing. I have mailed Andy but no joy as yet. Anyone got an updated driver or advice on what to do?
Cheers
wrighty
« Reply #61 on: May 21, 2008, 04:24:52 pm »
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/PyO0c8pVxRY&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/PyO0c8pVxRY&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Video of my mame monitor working! Sorry about vid being jerky crap camera phone!
grantspain
« Reply #62 on: May 21, 2008, 04:37:52 pm »
good to see it running,was it a driver fault?
wrighty
« Reply #63 on: May 22, 2008, 06:30:05 am »
Arragggh just seen my embedded youtube thing hasnt quite worked out!  :dizzy:
Yeah just a driver issue in the end.
Thanks for all your help with this grantspain! it is very much appreciated!!
