Author Topic: How does one accomplish the curve on top of machines like pac man?  (Read 3762 times)
havic626
  • -banned-
  • Last login:August 05, 2012, 05:11:42 am
How do you guys out there do it?  i mean cut those curves so nice and even like on the tops of pac man cabs and the ones like donkey kong jr. is there a tool out there that helps?
Re: How does one accomplish the curve on top of machines like pac man?
« Reply #1 on: April 05, 2008, 09:08:32 am »
Assuming you can draw the line with a pencil (I used one tied to a piece of string) all you do is cut close to the line with your jigsaw and sand to the line.  No magic involved!
fjl
  • Pixels Rule!
« Reply #2 on: April 06, 2008, 06:08:31 am »
You forgot to mention that once you have one side of the arcade complete doing the above method, you use a flush cutting bit with a router and use it to trace-cut an exact replica of the first side of the arcade leaving you with a perfect copy for the other side of the arcade. Routers are such miraculous tools. And to think, I went this far in life not even knowing that such a tool existed.
How did I ever get through life without a router? :dunno
valiant
  • Last login:March 05, 2022, 02:49:23 pm
  • One of three lions...
« Reply #3 on: April 10, 2008, 06:49:29 pm »
In order to generate accurate and smooth curves, I mocked up a simple pivot with a short piece of wood with a notch at one end for the pencil and a hole with a screw at the other.  This way I ensured the curve, which in my plans, were the same diameter for front monitor and rear over.
Marking out the circle
  • Last login:December 05, 2025, 04:38:46 pm
« Reply #4 on: April 20, 2008, 02:16:06 am »
Here is what I do:
http://forum.arcadecontrols.com/index.php?topic=75586.0
I usually use this method on a piece of MDF, and then sand down to perfect. I then use a router to trace out replica's.
amadama
  • Last login:September 29, 2019, 04:44:52 pm
« Reply #5 on: May 13, 2008, 01:34:57 pm »
Here's the method I used in my homemade Pac-man (similar to what leapinlew described in his post).
http://forum.arcadecontrols.com/index.php?topic=67464.0
Good luck!
Alex
