Author Topic: Mala Starting Picture is too small  (Read 3792 times)
Trebeck
  • "The Arcade" - Build #4
« on: March 29, 2008, 10:02:46 pm »
Hey all,
Quick question, I have designed a 800x600 startup picture for Mame, but when you start it the picture is the original small size.  Where in the layout editor can I change the numbers?  I looked around but didnt find anything.
Beck
loadman
  • Moderator
    • MaLa
Re: Mala Starting Picture is too small
« Reply #1 on: March 30, 2008, 05:00:50 am »
Start-up Picture?
Do you mean Layout Background?
I'm confused  ???
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: March 30, 2008, 08:31:45 am »
Maybe he means "startup video"?
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
« Reply #3 on: March 30, 2008, 12:20:30 pm »
i think its a fixed size window coz if you select lo-rez it goes even smaller
« Last Edit: March 30, 2008, 02:35:39 pm by Mr Wilson »
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #4 on: March 30, 2008, 07:50:52 pm »
I'm not following what you mean by Mala Starting Picture.  Do you mean the Mala splash screen that only comes up when you first start Mala?  Or do you mean the graphic that briefly shows whenever you start a game?  Or perhaps you mean the layout background picture?
Trebeck
« Reply #5 on: March 30, 2008, 10:17:26 pm »
Say when you go start Mala up and you're in the Mame layout and you pick a game (player 1), that second you may have a little box that shows up saying "starting" or something like that just before the game is loaded.  That's what I mean.  On my old config I had an 800X600 pic like this one:
SGT
« Reply #6 on: March 31, 2008, 01:22:06 pm »
I am assuming you're running a screen resolution higher than 800x600?  Do you have the settings configured similiar to the image below?  It works fine on my end.  No matter how small an image I'm using, Mala stretches it to full screen for me.
Trebeck
« Reply #7 on: March 31, 2008, 10:05:09 pm »
Sweet!  That did it.
I was looking all over the layout options for something but I was on the wrong end.
Thanks SGT
-beck
