Author Topic: How strong is elmer's wood glue?  (Read 1925 times)
noobofthecentury
  • Last login:April 15, 2008, 01:18:00 am
« on: March 21, 2008, 02:34:52 am »
How strong is this wood glue?
I bonded my control panel only with wood glue.
it seems ok.. but will it stand aggresive gaming?
the wood im using is MDF.
TOK
  • The Game Always Wins
Re: How strong is elmer's wood glue?
« Reply #1 on: March 21, 2008, 07:09:07 am »
If you built it in a way so there is a lot of contact area for the glue, I don't think you'll ever have a problem. With MDF, a layer will usually tear before the glue lets loose.
  • Last login:Yesterday at 01:49:32 pm
« Reply #2 on: March 21, 2008, 09:46:51 am »
The material will fail before the glue does.
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« Reply #3 on: March 21, 2008, 12:09:53 pm »
i used gorilla glue on mine, that stuff is freaking amazing
Jeff AMN
    • Gamer Theory
« Reply #4 on: March 21, 2008, 12:12:37 pm »
Yeah, Gorilla glue is incredible. That stuff will hold together better than screws and nails.
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #5 on: March 21, 2008, 12:23:17 pm »
Elmer's is some good stuff.  If you do it right the MDF with break before the glue gives.
17 years old and totaly addicted.
« Reply #6 on: March 21, 2008, 12:25:00 pm »
It's strong enough for you, old man.  It's the glue that held Kessel together for 12 parsecs.
Green Giant
« Reply #7 on: March 21, 2008, 04:03:51 pm »
People always say that but it isn't true.
The glue is crazy strong, but you are bonding the outermost layers of the wood together.
For the ultimate hold, drill a hole in the sheets, lube up a dowel with gorilla glue, and insert in the hole.   ;)
Toxic Arcade, my first build
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #8 on: March 21, 2008, 05:45:40 pm »
Gorilla glue is great, I use it almost exclusively.  I find that it can be a bit brittle, so I usually glue and screw to hold better and keep the joint from moving.
Xiaou2
  • Last login:Today at 03:03:54 am
  • NOM NOM NOM
« Reply #9 on: March 21, 2008, 06:40:44 pm »
My first test panel was glued together with hot glue.   It was only 6 sides (no bottom).   I was able to stand on it
and even jump up and down on it without any sign of it coming apart.
 Usually, trying to take apart such things results in the glue ripping the woods surface apart.
 Which is why I now use coarse wood screws whenever possible.   Things screwed can be
de-constructed, and the screws and wood can be re-used.
fjl
  • Pixels Rule!
« Reply #10 on: March 21, 2008, 11:50:20 pm »
Is gorilla glue water proof?
I use Titebond II for my wood working. It's weatherproof and from what I've read about it, highly recommended. Titebond III is supposedly "the best wood glue ever."
