February 17, 2026, 03:39:26 am
You can do HORM (hibernate once resume many times.) It is a little trick to get specialized installs (as in arcade machines) to startup faster and behave the same way at every start. It is also a good way to reduce the number of writes on a flash based system. I originally read about it at Mp3 Car.com You'll need to get a hold of some files from XP embedded; which is free to trial here.
