Author Topic: Re-use XP Hibernation file?  (Read 2562 times)
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
« on: March 20, 2008, 01:57:36 pm »
I'm want to get the quickest boot time possible in XP. I had an idea. Make a hibernation file in XP and find a way to have it load that same hiberfil.sys every time the PC starts (as well as pagefile.sys I'm guessing)
Does anyone know what the trigger is that makes XP load the hiberbation file into memory?
protokatie
Re: Re-use XP Hibernation file?
« Reply #1 on: March 20, 2008, 07:36:21 pm »
I forsee a problem with this. Since everytime windows shutdown, it stores that it has shut down properly, and when you turn it back on it wont even look for the hibernate file... You might be able to do it by just unplugging the computer tho...
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #2 on: March 20, 2008, 07:53:19 pm »
You cant wait like 30 seconds?  ;)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
gonzo90017
« Reply #3 on: March 20, 2008, 08:04:02 pm »
Have you tried making a sliptreamed xp? Head over to the Nlite thread.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #4 on: March 20, 2008, 11:49:07 pm »
You can do HORM (hibernate once resume many times.)  It is a little trick to get specialized installs (as in arcade machines) to startup faster and behave the same way at every start.  It is also a good way to reduce the number of writes on a flash based system.   I originally read about it at Mp3 Car.com
You'll need to get a hold of some files from XP embedded; which is free to trial here.
BTW; the guy on the first link got his startup down to about 10 seconds.
« Last Edit: March 20, 2008, 11:51:25 pm by NickG »
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #5 on: March 21, 2008, 09:55:19 am »
Good comment, I'd forgotton about playing with HORM no a embedded system years ago.
I've created a page on the wiki for speeding up windows boots (as there did not seem to be one), and included a section on HORM based on that thread.
Feel free to add, it's a bit rough and ready.
http://wiki.arcadecontrols.com/wiki/Fast_Booting_Windows
ncflagg
« Reply #6 on: March 25, 2008, 12:06:07 am »
I've installed HORM on XP Pro SP2 and it does work. However with EWF on I can't change any settings (or write to the hard drive). I've discovered I can disable EWF with EWFMGR C: -DISABLE (and am then able to write to the drive) but then HORM quits working. I can hibernate once but not more.
