Author Topic: Setup KeyWiz with Mala  (Read 2381 times)
MontanaVike
  • Last login:May 06, 2024, 06:25:24 pm
« on: March 01, 2008, 12:36:32 pm »
I am trying to setup my system.  I have a KeyWiz ST and am using Mala as my frontend.
If I manually upload the KeyWiz key setup then start Mala, everything works fine.  If I try to start the KeyWiz upload automatically (using the /A/L/PA modifiers) it fails miserably.  I get an error that says the KeyWiz was not detected.
How is the best way to setup Mala to use the default MAME keyset with the KeyWiz ST?
  • Last login:September 20, 2025, 07:17:24 am
Re: Setup KeyWiz with Mala
« Reply #1 on: March 05, 2008, 05:09:44 pm »
maybe Im missing something, but I dont think you need to do anything to use the mame default keys?
You dont need the uploader unless you are changing the default keys, i think.
