Author Topic: Spinner what Axis?  (Read 1744 times)
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
Spinner what Axis?
« on: February 28, 2008, 08:58:47 pm »
I have a TT2 spinner and a Happ USB 3 inch trackball. Just wondering if I should put it on the x,y, or Z axis? Is there any advantage or disadvantge to putting spinner  on Z axis? Also if I did put it on the Z Axis, which controls setting in Mame do I change?
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
Re: Spinner what Axis?
« Reply #1 on: February 28, 2008, 09:18:29 pm »
sometimes backspin will be a problem on the z axis...it was for me and at least one other guy...
i put it on the x axis and it was good to go...
if you put it on the y axis...then you could use it to scroll through your gamelist on mala...
bent98
« Reply #2 on: February 28, 2008, 09:21:17 pm »
No conflict with it sharing same as trackball?
Encryptor
  • Trade Count: (+34)
« Reply #3 on: February 28, 2008, 10:53:19 pm »
Maybe reading this thread will help you figure out which one to use.
http://forum.arcadecontrols.com/index.php?topic=75693.0
Encryptor
RandyT
  • Last login:October 15, 2025, 02:14:18 pm
    • GroovyGameGear.com
« Reply #4 on: February 29, 2008, 12:33:07 pm »
Not if the trackball is on a physically different interface board.  But they cannot both be connected to the same board and axis.
RandyT
