January 30, 2026, 08:35:47 am
You my friend have what is called "jail bars". A degaussing will not fix this.The monitor in this topic didn't have the earth ground connected correctly.http://forum.arcadecontrols.com/index.php?topic=72963.0If you would post a picture of your monitor chassis that would be great. Also, if a cap kit hasn't been done on this monitor it would be a good idea to do, may want to also change the flyback while you are at it just as preventative maintenance.
Here's some other info:http://jstookey.com/arcade/WG_25k7191/
