Author Topic: WG 25K7191  (Read 2291 times)
pincky
  • Last login:February 10, 2014, 02:22:07 pm
WG 25K7191
« on: February 24, 2008, 09:55:52 pm »
Hi on my cab
i wanted to know if I needed a cap kit for this or just a deguasing?
I shot some video
I found this sticker too this is what it said
Model No. 25K7191
120V 60Hz 100W Max
Wells-Gardner
Theres a Sticker on the Tube that Says Zenith
http://pincky.gotdns.com/Video
Files Are MKII.AVI
Startup.AVI
Let me know
« Last Edit: February 24, 2008, 11:08:10 pm by pincky »
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: Question On Montior
« Reply #1 on: February 24, 2008, 10:35:35 pm »
Downloading video now... put the WG 25K7191 in the subject line of the topic if you don't mind.  Per the sticky.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
Lutus
« Reply #2 on: February 24, 2008, 10:57:23 pm »
You my friend have what is called "jail bars".  A degaussing will not fix this.
The monitor in this topic didn't have the earth ground connected correctly.
http://forum.arcadecontrols.com/index.php?topic=72963.0
If you would post a picture of your monitor chassis that would be great.
Also, if a cap kit hasn't been done on this monitor it would be a good idea to do, may want to also change the flyback while you are at it just as preventative maintenance.
pincky
« Reply #3 on: February 24, 2008, 11:14:58 pm »
Just read that topic i found the ground wires its is connect to the neck card
the soddering job doesn't look that good
i will take some pics tommarow
Here is one picture i took but I will take some better ones tommarow
http://pincky.gotdns.com/Pictures/My%20Arcade%20Pictures/IMG_0862.JPG
pincky
« Reply #4 on: February 24, 2008, 11:20:18 pm »
CAP Kit
Okay i have located one on "The Real Bob Roberts" web Page
But i am a little scared to do myself, (fear of being electruted with 20k + volts!)
EDIT : I googled and i think i found someone i will give them a call tommarow
« Last Edit: February 24, 2008, 11:27:32 pm by pincky »
Ken Layton
  • Guru
  • Technician
Re: WG 25K7191
« Reply #5 on: February 24, 2008, 11:33:00 pm »
pincky
Re: WG 25K7191
« Reply #6 on: February 25, 2008, 12:52:22 am »
