Author Topic: Mala LedWiz plugin and trackball  (Read 8210 times)
mflis
  • Last login:November 19, 2018, 11:19:45 am
« on: February 22, 2008, 02:29:37 pm »
I just installed the GGG Electric ICE trackball kit and subsequently set up the Mala LedWiz plugin for P1_TRACKBALL (on ports 29, 30 and 31).  I was hoping that the trackball would light up when games that use the trackball were selected while scrolling through the game list in Mala.  All of the buttons light up correctly, but nothing seems to light up the trackball.  I have the latest controls.ini and I see trackball entries (albeit for P1_TRACKBALL_Y,  P1_TRACKBALL_X_EXT, P1_TRACKBALL_X, and P1_TRACKBALL_Y_EXT).  The trackball lights up correctly in the configurator (with the light panel on fly checkbox checked).  Is there something I'm missing?
CatttDaddy
  • Last login:May 11, 2019, 12:46:59 pm
    • CatttDaddy.com
Re: Mala LedWiz plugin and trackball
« Reply #1 on: February 23, 2008, 01:30:20 am »
What plugin are you using for Mala I believe there are 2 or 3 LED-WiZ plugins.
My suggestion is that if one doesn't work try another. If you are using LED-Blinky I would try The LED-Blinky thread here in the software section. Arzoo has really helped me with my LED-Blinky issues and is a really cool guy.
loadman
  • Moderator
    • MaLa
« Reply #2 on: February 23, 2008, 02:05:52 am »
Hi,
I just tried the Led-Wiz Plug-in I was invloved with V2.0
http://mala.arcadezentrum.com/plugins.html#LEDWiz
It works fine
The Leds I just allocated to a trackball worked fine with Centipede.
Did you refresh your gamelist?
Did you specify the path of this file in MaLa?
This is the controls ini data I have.
Code: [Select]
[centiped]
gamename=Centipede (revision 3)
numPlayers=2
alternating=1
mirrored=1
tilt=1
cocktail=1
usesService=0
miscDetails=
P1NumButtons=1
P1Controls=Trackball+trackball
P1_BUTTON1=Fire
P1_TRACKBALL_X=Left
P1_TRACKBALL_X_EXT=Right
P1_TRACKBALL_Y=Up
P1_TRACKBALL_Y_EXT=Down
« Last Edit: February 23, 2008, 02:21:26 am by loadman »
CatttDaddy
    • CatttDaddy.com
« Reply #3 on: February 23, 2008, 06:20:18 am »
I use LEDBlinky and it works great! It must be something configured incorrectly if you are using one of these two.
mflis
« Reply #4 on: February 23, 2008, 11:51:16 am »
Loadman - thanks for jumping in.  I am useing the the ledwiz plugin v2.0.  My controls.ini has exactly what you posted and I'm pointing at it from Mala.  I tried refreshing the game list to no avail.  Is there any debug logging flags I can turn on to get more information?  The trackball light up for the Mala start and game start effects, so I know it's hooked up.  I also tried specifying "always on" and it still does not light up.  Thoughts?
mflis
« Reply #5 on: February 23, 2008, 12:32:59 pm »
I also meant to mention that when the trackball correctly lights up when the attract mode kicks in.  Also, here is my ledwiz.cfg file:
1,1,1,1,0,5,1,3,200,0,0,,1,1,1,1,1
P1_COIN,1,SINGLE,0,0,0,0,0,0,0,28,48,0
P1_START,1,SINGLE,0,0,0,0,0,0,0,15,48,0
P1_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,1,48,0
P1_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,2,48,0
P1_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,3,48,0
P1_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,4,48,0
P1_BUTTON5,1,SINGLE,0,0,0,0,0,0,0,5,48,0
P1_BUTTON6,1,SINGLE,0,0,0,0,0,0,0,6,48,0
P1_BUTTON7,1,SINGLE,0,0,0,0,0,0,0,7,48,0
P1_TRACKBALL,1,RGB,29,30,31,48,5,48,1,0,0,0
P2_START,1,SINGLE,0,0,0,0,0,0,0,16,48,0
P2_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,8,48,0
P2_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,9,48,0
P2_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,10,48,0
P2_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,11,48,0
P2_BUTTON5,1,SINGLE,0,0,0,0,0,0,0,12,48,0
P2_BUTTON6,1,SINGLE,0,0,0,0,0,0,0,13,48,0
P2_BUTTON7,1,SINGLE,0,0,0,0,0,0,0,14,48,0
P3_START,1,SINGLE,0,0,0,0,0,0,0,26,48,0
P3_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,17,48,0
P3_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,18,48,0
P3_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,19,48,0
P3_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,20,48,0
P3_BUTTON5,1,SINGLE,0,0,0,0,0,0,0,25,48,0
P4_START,1,SINGLE,0,0,0,0,0,0,0,27,48,0
P4_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,21,48,0
P4_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,23,48,0
P4_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,22,48,0
P4_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,24,48,0
Thanks again for any insights...
loadman
  • Moderator
    • MaLa
« Reply #6 on: February 23, 2008, 05:18:33 pm »
Yeah,
From what you say the Lidwiz is woired up OK and the Led-Wiz Config looks OK.
I don't think any logs will reveal anything
I think the question is if MaLa is passing the controls.ini data to the plug-in.?
Anyway,
Have you tried chnaging what LEDS are allocated to Trackball (just temp) to see if that works?
can you post your mala.ini file please
« Last Edit: February 23, 2008, 06:35:11 pm by loadman »
mflis
« Reply #7 on: February 23, 2008, 09:48:20 pm »
I will try setting a different LED for P1_TRACKBALL and let you know how that goes.  In the meantime, here's my mala.ini.  I'm software developer by trade and can usually debug problems, but this one is giving me trouble....
[Hardware1]
Enabled=0
ID=
[Hardware2]
Enabled=0
ID=
[Hardware]
UseLCD=0
UseLED=0
[LCD]
Rows=2
Cols=16
[GUI]
ShowTaskbar=1
DisableSplash=0
SplashTime=0
Vertical=0
Flip=0
RunApplicationOnExit=0
UseStartingPicture=0
UseStartingPictureFromLayout=0
ChangeResolution=0
ChangeResolutionToFixedSize=0
ChangeResolutionOnOptions=0
ChangeResolutionFixedSize=640x480x32
OrientationFilter=0
ShowSnap=1
ShowVideo=1
DisableVideoSound=0
KeyRepeat=200
SmallMenu=0
KeepAspectRatio=1
VideoKeepAspectRatio=1
RotateGameLists=0
RotateEmulators=0
UseScrollDelay=1
ScrollDelay=50
UseScrollExceptionText=1
UseScrollExceptionHardware=0
UseScrollExceptionSound=0
UseScrollExceptionAnimation=0
UseScrollExceptionSnap=1
UseScrollExceptionMarquee=0
UseScrollExceptionCPanel=0
UseScrollExceptionGameSelectEvent=1
UseScrollExceptionDefinable1=0
UseScrollExceptionDefinable2=0
UseScrollExceptionDefinable3=0
UseScrollExceptionDefinable4=0
PictureQuality=1
InfoWindowSize=6
TrackSelection=1
RandomStartsGame=0
ShowHints=1
RotateClockwiseOnVertical=0
LockExit=0
RemoveBracketsFromNames=0
ReorderLayoutAfterGameQuit=0
VideoDisplayDelay=0
VideoDisplayDelayInterval=1000
AutoGamelistSwitch=0
Browse=0
SelectedGame=165
RunApplicationOnExitPath=
StartingPictureH=
StartingPictureV=
AutoGamelistSwitchH=All Games
AutoGamelistSwitchV=All Games
[Debug]
Log=0
[MaLa]
FirstTimeRun=0
[Fades]
Start=1
Quit=0
Out=1
In=1
Menu=1
FastCount=5
SlowCount=25
[Screensaver]
Active=1
Interval=300000
DisplayInterval=10000
RandomDisplay=0
PluginEventOnly=0
UseGamelist=0
UseEmulator=0
SearchInSubfolders=0
UsePictures=1
DisableVideoSound=0
UseWatermarkImage=0
StretchToFullscreen=0
Snaps=C:\mame\snap
Videos=
[Exit]
Action=0
AlternativeShutdownMethod=0
[Starting]
UseStarting=0
Emulator=0
Game=0
RandomGame=0
LastPlayedGame=0
PlayVideoOnStart=0
StartingList=All Games.mlg
StartVideoFilename=
[Encoder]
UseEncoderProgramming=0
EncoderWindowState=1
EncoderCommandLine=%config%
EncoderSendFullPath=1
EncoderQuoteConfigPath=0
EncoderSmartProgramming=0
DisplayMessageBox=0
PathEncoderSoftware=
EncoderDefaultConfig=
[JukeBox]
UseJukebox=0
Title=Jukebox
BaseDir=C:\MaLa\
Mode=1
DisableGUISounds=0
CoverFilename=
[Joystick]
UseJoystick=0
UseJoystick2=0
Repeat=200
DeadZone=50
[JoySet0]
1Up=0
1Down=0
XUp=0
XDown=0
LetterUp=0
LetterDown=0
StartGame=0
StartRandomGame=0
SwitchOrientation=0
FlipOrientation=0
Exit=0
MenuOpenClose=0
MenuSelect=0
AddGameToList=0
RemoveGameFromList=0
PreviousList=0
NextList=0
PreviousEmulator=0
NextEmulator=0
InfoOpenClose=0
InfoSelect=0
VolumeUp=0
VolumeDown=0
NextSong=0
PreviousSong=0
[JoySet1]
1Up=0
1Down=0
XUp=0
XDown=0
LetterUp=0
LetterDown=0
StartGame=0
StartRandomGame=0
SwitchOrientation=0
FlipOrientation=0
Exit=0
MenuOpenClose=0
MenuSelect=0
AddGameToList=0
PreviousList=0
NextList=0
PreviousEmulator=0
NextEmulator=0
InfoOpenClose=0
InfoSelect=0
VolumeUp=0
VolumeDown=0
NextSong=0
PreviousSong=0
[Mouse]
UseMouse=0
UseSteadyKey=0
ReverseAxis=0
ExchangeAxis=0
Repeat=100
[Emulator]
Typ=0
Selected=0
[Mame]
Title=M.A.M.E. v0.123
NamingDefinable1=0
NamingDefinable2=0
NamingDefinable3=0
NamingDefinable4=0
SearchInSubDirs=0
UseMasterPicturesForClones=1
Commandline=%rom%
EncoderGameBased=0
WindowState=0
AutoRotate=0
AutoRotateMaLa=0
ShowControlsOnStart=0
UseCPViewer=1
ReplaceInfoWindowWithCPViewer=1
HideAllGamesList=0
Exe=C:\MAME\MAME.EXE
Snaps=C:\Mame\snap
Marquee=C:\Mame\marquees
CPanel=C:\Mame\cpanel
Definable1=
Definable2=
Definable3=
Definable4=
Video=
InfoFile=C:\MAME\mame.xml
Roms1=C:\Mame\roms
Roms2=
Roms3=
CatverFile=C:\Mame\catver.ini
ControlsFile=C:\Mame\controls.ini
NPlayersFile=C:\Mame\nplayers.ini
HistoryFile=C:\Mame\history.dat
MameInfoFile=c:\mame\mameinfo.dat
EncoderFile=
EncoderConfigFilesPath=
EncoderConfigFileExtension=
CPViewerExecutable=c:\johnny5\Johnny5.exe
CPViewerCommandLine=%rom%
[GameList]
SelectedGameList=Working Games
Filter1Typ=0
Filter1=Off
Filter2Typ=1
Filter2=Off
Filter3Typ=2
Filter3=Off
Filter4Typ=3
Filter4=Off
Having=1
Working=1
Preliminary=0
Master=0
Excludes=
[Layout]
SelectedLayout=standardsnap
SwitchWithEmulator=0
SwitchWithGamelist=0
UseLayoutNameAsDir=1
DisableAnimation=0
SearchDefinablesInLayoutPath=0
LayoutDirectory=
[tree]
UseTree=0
MenuSnaps=
[Ctrl]
MappingScreenRotation=0
SelectedControllerSet=0
MappingAutoDetectController=0
MappingSwitchGamelist=0
UseKeyForOptionsDialog=0
OptionsDialog=0
UpInterval=10
DownInterval=10
OnePage=1
UseLetters=0
UseCocktailMapping=0
UseScrollingAcceleration=1
ScrollingAccelerationSpeed=10
MouseUseScrollingAcceleration=1
MouseScrollingAccelerationSpeed=10
JoyUseScrollingAcceleration=1
JoyScrollingAccelerationSpeed=10
[CtrlSet0]
1Up=38
1Down=40
XUp=37
XDown=39
LetterUp=293
LetterDown=295
StartGame=49
StartRandomGame=51
SwitchOrientation=0
FlipOrientation=0
Exit=27
MenuOpenClose=50
MenuSelect=49
AddGameToList=0
PreviousList=338
NextList=326
PreviousEmulator=324
NextEmulator=327
VolumeUp=65
VolumeDown=83
PreviousSong=0
NextSong=0
InfoOpenClose=53
InfoSelect=32
LaunchApp1=0
LaunchApp2=0
LaunchApp3=0
SteadyKey=32
[CtrlSet1]
1Up=38
1Down=40
XUp=294
XDown=296
LetterUp=0
LetterDown=0
StartGame=49
StartRandomGame=305
SwitchOrientation=0
FlipOrientation=0
Exit=27
MenuOpenClose=50
MenuSelect=49
AddGameToList=0
PreviousList=37
NextList=39
PreviousEmulator=293
NextEmulator=295
VolumeUp=0
VolumeDown=0
PreviousSong=0
NextSong=0
InfoOpenClose=18
InfoSelect=32
LaunchApp1=0
LaunchApp2=0
LaunchApp3=0
SteadyKey=17
[CtrlSet2]
1Up=38
1Down=40
XUp=294
XDown=296
LetterUp=0
LetterDown=0
StartGame=49
StartRandomGame=305
SwitchOrientation=0
FlipOrientation=0
Exit=27
MenuOpenClose=50
MenuSelect=49
AddGameToList=0
PreviousList=37
NextList=39
NextEmulator=295
VolumeUp=0
VolumeDown=0
PreviousSong=0
NextSong=0
InfoOpenClose=18
InfoSelect=32
LaunchApp1=0
LaunchApp2=0
LaunchApp3=0
SteadyKey=17
[CtrlSet3]
1Up=38
1Down=40
XUp=294
XDown=296
LetterUp=0
LetterDown=0
StartGame=49
StartRandomGame=305
SwitchOrientation=0
FlipOrientation=0
Exit=27
MenuOpenClose=50
MenuSelect=49
AddGameToList=0
PreviousList=37
NextList=39
NextEmulator=295
VolumeUp=0
VolumeDown=0
PreviousSong=0
NextSong=0
InfoOpenClose=18
InfoSelect=32
LaunchApp1=0
LaunchApp2=0
LaunchApp3=0
SteadyKey=17
[CtrlMap0]
Set=6
Gamelist=All Games
CommandLine=
[CtrlMap1]
Set=6
Gamelist=All Games
CommandLine=
[CtrlMap2]
Set=6
Gamelist=All Games
CommandLine=
[CtrlMap3]
Set=6
Gamelist=All Games
CommandLine=
[Sounds]
Enabled=1
DisplayVolumeMessage=0
UseSoundsFromLayout=0
UseBGMusicFromLayout=0
Movement=
StartGame=
TreeUpDown=
QuitGame=
EndReached=
ListSwitch=
EmuSwitch=
OrientationSwitch=
AttractMode=
MenuSelect=
Exit=
[BGMusic]
Status=1002
Volume=56
LastSong=0
LastSongPos=1426221
PauseOnGameStart=1
UseFades=1
FadeInterval=15
Shuffle=0
Repeat=1
StartFromLastPosition=0
[AutoGameList]
Enabled=0
Max=10
[LED]
OffWhileGaming=0
FlashOnGameStart=1
FlashOnGameStartCount=5
FlashOnGameStartInterval=50
DirGameFiles=
[AttractMode]
UseAttractMode=0
Interval=30000
Selected=mala
Random=0
RandomRefresh=0
Randomizer=0
RandomizerLength=5000
RandomizerMinDuration=50
RandomizerMaxDuration=500
[LEDEvent]
MalaStart=0
MalaStartSequence=LED_CONFIGS
MalaExit=0
MalaExitSequence=LED_CONFIGS
GameStart=0
GameStartSequence=LED_CONFIGS
GameExit=0
GameExitSequence=LED_CONFIGS
EmuSwitch=0
EmuSwitchSequence=LED_CONFIGS
GamelistSwitch=0
GamelistSwitchSequence=LED_CONFIGS
[ExternalApps]
App1_0=
App1_1=
App1_2=
App2_0=
App2_1=
App2_2=
App3_0=
App3_1=
App3_2=
mflis
« Reply #8 on: February 24, 2008, 01:31:20 pm »
I switched P1_TRACKBALL to use the LED in P1_BUTTON7 (a single LED) and P1 button 7 does not light up in Mala when centipede is selected.  Does this point in the direction of what Mala is sending to the plugin?
loadman
  • Moderator
    • MaLa
« Reply #9 on: February 24, 2008, 05:09:05 pm »
I would think so.  I will test your mala.ini when I get home
loadman
  • Moderator
    • MaLa
« Reply #10 on: February 27, 2008, 04:36:31 am »
OK
So that looks fine.
If you change other data (like number of buttons) in your controls.ini and then refresh your game list does that effect your led display?
mflis
« Reply #11 on: February 27, 2008, 10:07:09 am »
I'll try it out this evening.
loadman
  • Moderator
    • MaLa
« Reply #12 on: February 27, 2008, 05:56:58 pm »
Weird man  :dizzy:
mflis
« Reply #13 on: February 27, 2008, 10:05:23 pm »
Well, I modified controls.ini which is in my c:\mame subdir and it made no difference.  I changed Burger Time [btime] to "P1NumButtons=3" and added "P1_BUTTON2=Pepper1" and "P1_BUTTON3=Pepper2" refreshed the game list and only the P1B1 lit up in Mala.  So it appears that it is not using controls.ini (correct?).    I've configured controls.ini to c:\mame\controls.ini.
mflis
« Reply #14 on: February 27, 2008, 11:35:10 pm »
So is it pulling the info from mame.xml?
   <game name="centiped" sourcefile="centiped.c">
      <description>Centipede (revision 3)</description>
      <year>1980</year>
      <manufacturer>Atari</manufacturer>
      <rom name="136001-307.d1" size="2048" crc="5ab0d9de" sha1="8ea6e3304202831aabaf31dbd0f970a7b3bfe421" region="cpu1" offset="2000"/>
      <rom name="136001-308.e1" size="2048" crc="4c07fd3e" sha1="af4fdbf32c23b1864819d620a874e7f205da3cdb" region="cpu1" offset="2800"/>
      <rom name="136001-309.fh1" size="2048" crc="ff69b424" sha1="689fa560d40a384dcbcad7c8095bc12e91875580" region="cpu1" offset="3000"/>
      <rom name="136001-310.j1" size="2048" crc="44e40fa4" sha1="c557db83876afc8ab52047ab1a3c3bfef34d6351" region="cpu1" offset="3800"/>
      <rom name="136001-211.f7" size="2048" crc="880acfb9" sha1="6c862352c329776f2f9974a0df9dbe41f9dbc361" region="gfx1" dispose="yes" offset="0"/>
      <rom name="136001-212.hj7" size="2048" crc="b1397029" sha1="974c03d29aeca672fffa4dfc00a06be6a851aacb" region="gfx1" dispose="yes" offset="800"/>
      <rom name="136001-213.p4" size="256" crc="6fa3093a" sha1="2b7aeca74c1ae4156bf1878453a047330f96f0a8" region="proms" offset="0"/>
      <chip type="cpu" name="M6502" clock="1512000"/>
      <chip type="audio" name="POKEY" clock="1512000"/>
      <display type="raster" rotate="270" width="256" height="240" refresh="60.000000" />
      <sound channels="1"/>
      <input players="2" buttons="1" coins="2" tilt="yes">
         <control type="joy8way"/>
         <control type="trackball" minimum="0" maximum="255" sensitivity="50" keydelta="10" reverse="yes"/>
      </input>
      <dipswitch name="Cabinet">
         <dipvalue name="Upright" default="yes"/>
         <dipvalue name="Cocktail"/>
      </dipswitch>
      <dipswitch name="Service Mode">
         <dipvalue name="Off" default="yes"/>
         <dipvalue name="On"/>
      </dipswitch>
      <dipswitch name="Language">
         <dipvalue name="English" default="yes"/>
         <dipvalue name="German"/>
         <dipvalue name="French"/>
         <dipvalue name="Spanish"/>
      </dipswitch>
      <dipswitch name="Lives">
         <dipvalue name="2"/>
         <dipvalue name="3" default="yes"/>
         <dipvalue name="4"/>
         <dipvalue name="5"/>
      </dipswitch>
      <dipswitch name="Bonus Life">
         <dipvalue name="10000"/>
         <dipvalue name="12000" default="yes"/>
         <dipvalue name="15000"/>
         <dipvalue name="20000"/>
      </dipswitch>
      <dipswitch name="Difficulty">
         <dipvalue name="Easy" default="yes"/>
         <dipvalue name="Hard"/>
      </dipswitch>
      <dipswitch name="Credit Minimum">
         <dipvalue name="1" default="yes"/>
      </dipswitch>
      <dipswitch name="Coinage">
         <dipvalue name="2 Coins/1 Credit"/>
         <dipvalue name="1 Coin/1 Credit" default="yes"/>
         <dipvalue name="1 Coin/2 Credits"/>
         <dipvalue name="Free Play"/>
      </dipswitch>
      <dipswitch name="Right Coin">
         <dipvalue name="*1" default="yes"/>
         <dipvalue name="*4"/>
         <dipvalue name="*5"/>
         <dipvalue name="*6"/>
      </dipswitch>
      <dipswitch name="Left Coin">
         <dipvalue name="*2"/>
      </dipswitch>
      <dipswitch name="Bonus Coins">
         <dipvalue name="None" default="yes"/>
         <dipvalue name="3 credits/2 coins"/>
         <dipvalue name="5 credits/4 coins"/>
         <dipvalue name="6 credits/4 coins"/>
         <dipvalue name="6 credits/5 coins"/>
         <dipvalue name="4 credits/3 coins"/>
      </dipswitch>
      <driver status="good" emulation="good" color="good" sound="good" graphic="good" savestate="supported" palettesize="260"/>
   </game>
loadman
  • Moderator
    • MaLa
« Reply #15 on: February 28, 2008, 04:19:26 am »
I think. From Memory  :-\
That MaLa uses the xml file but info from Controls .ini over-rides it.
Maybe there is something wrong with your controls .ini file?
Does the mala.exe.log tell you anything when you enable logging (in the credits section)?
It's gotta be something simple.
Do you want me to send you my working controls.ini file?
loadman
  • Moderator
    • MaLa
« Reply #16 on: February 28, 2008, 04:22:56 am »
mflis
« Reply #17 on: February 28, 2008, 05:20:16 pm »
I'll try turning on the logging and see what happens.  I downloaded controls.ini from http://fe.donkeyfly.com/controls/controls.php, but it couldn't hurt to diff it with your working copy.
loadman
  • Moderator
    • MaLa
« Reply #18 on: February 28, 2008, 06:58:00 pm »
Also for your fault finding.
You may find the attached plug-in useful.
It is the demo plug-in from the MaLa SDK.
What it does is simply log all info sent from MaLa to the MaLa plug-ins.
So it shows the data from controls.ini.
Data is saved in a text file called events.log.
This may save you some time working out the fault.
This logging is not be confused with a MaLa.exe.log which is an optional global log for mala. This is creted if the checkbox is checked in the credits section of mala config.
mflis
« Reply #19 on: February 28, 2008, 10:26:40 pm »
That demo plug-in should be very useful.  Even if it is pulling it from mame.xml, there is trackball specified in there.  Thanks for taking all of the time to help me with this.
mflis
« Reply #20 on: March 03, 2008, 07:42:14 pm »
Well, I''m still confused.  Here's the events.log section when centiped is selected (and it shows Trackball):
EVENT: Game selected
Name: Centipede (revision 3)
Manufacturer: Atari
Genre: Sparatutto / Bersagli
Year: 1980
Clone of:
-------------------- INPUTS ---------------------------------
Coins: 2
Buttons: 1
Players: 2P alt
Control: trackball
-------------------- VIDEO ----------------------------------
Screen: raster
Orientation: vertical
Video size: 256x240
-------------------- DRIVER ---------------------------------
Status: good
-------------------- CONTROLS.INI ---------------------------
Control: Trackball
JoyUp:
JoyDown:
JoyLeft:
JoyRight:
Button1: Fire
Button2: not used
Button3: not used
Button4: not used
Button5: not used
Button6: not used
Button7: not used
Button8: not used
-------------------- ROMFILE --------------------------------
Rom name: centiped
Rom path: C:\Mame32b\roms
Rom extension: zip
-------------------- STATS ----------------------------------
Game played: 4
mflis
« Reply #21 on: March 03, 2008, 07:55:55 pm »
All right, I'm an idiot.  My ledwiz_configurator.exe (and ocx_installer et al) are in a LedWiz subdir under plugins.  The ledwiz.cfg  was being update in this subdir.  I needed to copy it to the parent plugins subdir and everything worked great.  Thanks for all of the help and sorry for spinning yor wheels.
loadman
  • Moderator
    • MaLa
« Reply #22 on: March 03, 2008, 08:40:34 pm »
Thanks for posting the result.  I was scratching my head  ;)
