Author Topic: Monitor Question  (Read 2569 times)
helpmebuild
  • Last login:November 28, 2010, 06:32:26 pm
Monitor Question
« on: February 18, 2008, 02:02:27 pm »
Hey again all,
OK so I am trying to finalize my parts for ordering and getting everything down. I have done some serious searching and reading on the topic of connecting a computer to an exsisting arcade monitor but am still a little confused. Some of the pages, including the monitor guide I found here seem ancient and very intense. I'm aware that much like older tube televisions these monitors can store a ton of juice and kill you if you touch them in the wrong place, so I am weary about any kind of serious contact with them. My question is this: is there a simple way to connect my Wells Gardner U2000 monitor to my PC without any risk of blowing myself across the room? I have seen numerous parts on Ultrimac and they seem to be what I need I think but am not 100% sure if they will do the trick? Is this as simple as buying a ArcadeVGA Card and connecting it?
« Last Edit: February 18, 2008, 02:18:45 pm by helpmebuild »
grantspain
Re: Monitor Question
« Reply #1 on: February 18, 2008, 02:35:55 pm »
yes an arcade vga card would work fine,you would have to do a little wiring for the video input
helpmebuild
« Reply #2 on: February 18, 2008, 03:06:06 pm »
would have to do a little wiring for the video input if i DIDNT go with the Arcade VGA? or will I still need to wire with use of that card?
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
« Reply #3 on: February 18, 2008, 03:18:52 pm »
Yes, you still need to connect the cable from the ArcadeVGA to your monitor....
But it's nowhere near the "F-Points"......
SirPeale
  • Green Mountain Man
« Reply #4 on: February 18, 2008, 03:19:41 pm »
Dude, in this hobby, it's almost nothing BUT wiring.  Get used to it!   :D
grantspain
« Reply #5 on: February 18, 2008, 03:45:05 pm »
its only 5 wires to connect,nothing scary.
also it is extremely difficult to kill yourself with an arcade monitor,i know because i have tried loads of times :blowup:
