Author Topic: Reconditioning Nintendo 4-Way Joystick or Alternative  (Read 17921 times)
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: Reconditioning Nintendo 4-Way Joystick or Alternative
« Reply #40 on: August 29, 2008, 06:02:52 pm »
I played Mike's full panel with the previous "replacement" stick yesterday and I didn' t like it at all. Way to stiff.  I'm NOT talking about the new reproductions, this was the stick that came in the complete DK repro CP. It also seemed not correctly mounted, I had to hit the stick against the CP plexi to get it to go up. Sometimes it didn't respond or was just that deciding moment too late. Re-aligning the joystick might fix this, but it wasn't my machine.....
Ack!  That's not right!  Please have the guy who purchased that panel contact me.  The stick should work well and you shouldn't have to bang on it to make it work in any direction.
 - Mike -
DonkeyKong
  • Last login:January 05, 2016, 11:59:50 pm
  • How High Can You Get? Currently I'm at 145,200
« Reply #41 on: August 29, 2008, 06:05:05 pm »
 - Mike -
When you go looking for problems with your products, THAT's good service!
Everybody, even Grandma, games. Meaning, checkers, cards, if not now, in the past.  Show me even a frickin' nun or hermit who hasn't done cards or checkers. -Mark Alpiger
jimkirk
  • Last login:October 27, 2013, 01:24:15 am
  • Ahead warp factor 5 Mr. Sulu.
« Reply #42 on: August 31, 2008, 04:34:16 pm »
 - Mike -
Yes Mike has the best customer service. If there is a problem he will take care of it pronto. Shipping is also very fast. I recommend all the time.
I know who Phet is and many of you do not.
Level42
« Reply #43 on: September 01, 2008, 05:47:35 pm »
PM sent Mike :)
MaximRecoil
« Reply #44 on: September 02, 2008, 11:34:44 am »
I don't know if Mike has made an announcement here or not, but he has a prototype Super Punch-Out joystick, which, in kit form, can convert an original standard Nintendo joystick, or one of his reproductions, to an SPO joystick without making any permanent changes (no drilling or anything). He came up with a very clever way of attaching the bracket for the 5th microswitch. Instead of screwing directly to the side of the base like the originals do, he designed the bracket to be secured by the same carriage bolts that secure the joystick to the control panel, which is how he made it so people wouldn't have to drill their joystick or make any other permanent changes to convert it to an SPO joystick. So if you want an authentic way to control SPO or Arm Wresting in MAME (2-way restrictor should be used for Arm Wrestling rather than the 4-way for SPO), this is it; and of course this is also perfect for converting an original Punch-Out to SPO or AW.
I never thought I'd see the day. Original SPO joysticks are about as common as hen's teeth, and their lack of availability was a major stumbling block for people wanting to play SPO correctly.
I am in no way affiliated with Mike's Arcade BTW, it is just that I've been hoping for a reproduction of the various Nintendo joysticks, particularly the rare SPO joystick for such a long time.
You can see in that picture the clever no-modification method of attaching the bracket for the 5th microswitch that Mike came up with. More pictures here.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #45 on: September 02, 2008, 12:10:02 pm »
That's pretty darn cool ...
Working: Not Enough
Projects: Too Many
Progress: None
