Author Topic: I-pac2 or mini pac? whats the difference between _ buttons?  (Read 1878 times)
JKD The Lad
  • Last login:December 19, 2011, 07:12:51 pm
« on: January 15, 2008, 01:38:11 am »
I have two quick questions:
1. is there any big advantage over getting a I-pac2 over the mini?
From what I've read the Mini is much easier to install and seems to also have the ability to work as a opti-pac
I'm making 2 boards, one with 2 8-way joysticks, 2 pairs of 16 buttons (plus a shift) and a second board with a spinner, trackball 6 buttons and a 4/8-way joystick
Before I order is there any reason why I would want a to buy a I-pac2 for ether of them instead of 2 mini-pacs?
2.Regarding buttons: whats the difference between the "PUSHBUTTON WITH HORIZONTAL MICROSWITCH" and the
"ULTIMATE PUSHBUTTON WITH MICROSWITCH" on the happs website?
I'm still trying to decide what sort of buttons to buy.
LeedsFan
Re: I-pac2 or mini pac? whats the difference between _ buttons?
« Reply #1 on: January 15, 2008, 03:15:55 am »
I copied this from the Ultimarc site for you:
"The I-PAC2 has 28 inputs. They are all programmable and are designated as 2 joysticks, 8 buttons each, plus coin1, coin2, start1, start2. One of the inputs is assigned as a shift key to access an alternate code set."
The Minipac is basically the same but with trackball/spinner inputs too. My advice is to get the Minipac for the board with the trackball/spinner. Minipac can also be bought with the correct wiring sockets for either Happs or Ultimarc trackballs.
The I-PAC will do you fine for the other board. Of course there's nothing to stop you using a Minipac on that one too and you have the option to use the trackball/spinner inputs at a later date if you choose to. The Minipac is about half the size of the I-PAC due to the way the wires connect to the boards. I wouldn't say either of them is "easier" to install than the other unless you were really cramped for space.
I'm not too sure about the buttons. Can't comment on them really.
JKD The Lad
« Reply #2 on: January 15, 2008, 03:31:23 am »
 ;D  Thanks for the help!
I had read that bit about inputs on the site and thats what I figured but seeing a lot of form members buy I-pac2s instead of mini's made me worry there was something I was missing.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: January 15, 2008, 04:06:39 pm »
2.  The difference is the ultimates suck.   ;)
Technically, the switch is mounted vertically on the ultimates, and the thingie that translates the vertical button movement into a horizontal to depress the switch is not as good as the other buttons.  The only nice thing about the ultimates is you don't need to remove the switch to screw/unscrew the button; however, you need to remove the wires (or the switch) to remove the button anyway, so it's a minor bonus in exchange for poorer game play.
Get the horizontals.
Robin
Knowledge is Power
Zakk
  • Last login:Today at 01:35:01 am
« Reply #4 on: January 15, 2008, 05:03:50 pm »
I actually prefer the ultimates, It's a lot smoother motion on the buttons, because they are rubbing along the actuator switch, not slamming down on it.  Again, personal preference...and truth be told, I almost always install the horizontal buttons, I have the vertical ones on my personal machine, along with cherry microswitches with "green" actuator buttons.  Man, those things are just like tapping air.  If I could find a place that sold those "green" versions, I'd buy them out :)
JKD The Lad
« Reply #5 on: January 16, 2008, 07:21:40 pm »
Thanks for the advice guys! Its all been very helpful
I think I'll grab the horizontal buttons!
