Author Topic: Boosting ouput on CRT PC monitor? Anyone tried it?  (Read 1697 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: December 27, 2007, 06:26:42 pm »
Hey all!
I take it that we all agree that PC monitors can appear a little 'flat' in the output for use with
arcade and TV. That's probably one of the reasons why many use arcade monitors in their
cabinets(among others)
So, I thought...is it possible to boost the output on the hardware in monitors? I could do this
always on CRT projectors, but maybe some PC monitors has the same 'feature'..
Doing it at the source only give you very nice clipping, and we don't want that! ;D
What do you think?
Edit: I have an Extron RGBHV booster from back in the day, set for long cable runs. Maybe that
could be used to get a higher than .7mV at the inputs of the monitor
« Last Edit: December 27, 2007, 06:34:18 pm by AE35 »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Boosting ouput on CRT PC monitor? Anyone tried it?
« Reply #1 on: December 27, 2007, 10:57:06 pm »
the harder the cathodes are driven, the shorter the crt operative life .
this has not changed from the early days of vacuum tubes.
i have had a few customers wear out a crt within the 2yr warranty period .
EACH customer ran their tv 24/7 @ full contrast and higher than normally accepted brightness.( why ?????  :dunno)
told each NOT to do same with the new crt   !   and had no callbacks  ;D
qrz
AE35
« Reply #2 on: December 28, 2007, 08:09:31 am »
Sure, but in this case the monitor won't be running 24/7...and with a much lower resolution and
refreshrate.
So I don't think CRT life will be affected much.
