Author Topic: Cant play Speed Racer [Solved]  (Read 1879 times)
zobook
  • Last login:March 08, 2019, 12:34:43 pm
« on: December 27, 2007, 10:00:36 am »
I tried to run Speed Racer but im stuck in the configuration screen. I read some post that explain hoy to doit but does not seems to work. I suposed to set off the "Test Swich" at the end but there is no switches for that game, i push the test button (F2 or F3, dont remember right now) to enter the config. But cant exit and start playing
Anyone can help
« Last Edit: December 28, 2007, 03:04:10 pm by zobook »
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
Re: Cant play Speed Racer
« Reply #1 on: December 27, 2007, 01:02:45 pm »
I have the same problem.
Been trying to figure it out for awhile now.
Z
superart
  • Permanent ban
  • Last login:April 29, 2008, 07:16:11 pm
  • Permanent ban
« Reply #2 on: December 28, 2007, 12:34:38 pm »
edit
« Last Edit: April 29, 2008, 01:01:53 am by Suits00 »
zobook
« Reply #3 on: December 28, 2007, 02:57:30 pm »
No, wasn't those instructions.
The ones you suggest works!!!!!
Thanks a lot!!!!!
« Last Edit: December 28, 2007, 03:03:46 pm by zobook »
Zeppo
Re: Cant play Speed Racer [Solved]
« Reply #4 on: December 28, 2007, 04:19:07 pm »
I've never seen those instructions.
About the only thing I ever found was people saying you needed to hit the Test button to exit the test mode.
I must admit I never looked too deep into solving it, and only remembered when I saw this post.
Z
superart
  • Permanent ban
  • Permanent ban
« Reply #5 on: December 28, 2007, 06:28:01 pm »
edit
« Last Edit: April 29, 2008, 01:02:04 am by Suits00 »
Zeppo
« Reply #6 on: February 04, 2008, 08:13:59 pm »
Believe it or not, I am just remembering about this again. =)
So I go and try to do the setup, but the steering will only register as going to the right even though I am hitting the left arrow button.
Also tried configuring it with the spinner as the steering wheel, and it only goes to the right as well.
Anyone have any hints?
Z
