Author Topic: Korean Joysticks  (Read 12607 times)
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Korean Joysticks
« on: December 23, 2007, 07:56:12 am »
The Korean joysticks do not use the spring only rubber ring. Smillar how Wico.
They have very smooth movement - very comfortable. They are good to fighter but they are not suitable to shmups and platform (long throw), 8way mode only:( Unfortunately they are not precise, centre to center unequatly.
manufacturers:
CROWN
Crown Joystcik are worse qualitatively from Sanwa or iL but better from Chinese  :laugh2: - copies differ, small mistakes in constructions, you can buy 4 and every will act differently (different strength of rubber ring), crapy microswitches... :blah:
If you will buy Korean joystcik on DECO microswitches - alter microswitches! DECO is crap. I recommend Omron V series They on omron act a lot better!
CLW302 - nicely executed, it acts similarly how JLW (J-stick) - korean copy, this only korean model which has not rubber ring. Full spring Action. I do not command him he has not no advantages in playing. JLW is better. Produce is stoped! (white crow)
  • rotation = square
  • throw = angle - 11 degree; travel - 13mm
  • engage = angle - 7 degree; travel - 8mm
  • diagonal = range 20 degree; hitting 80%
  • force to engage = force to engage = 0,44kG
CLW303 - similar to Fanta, very soft, my disastrous diagonals, it was it been possible to improve - bend lever microswitches.
  • rotation = circle
  • throw = angle - 13 degree; travel - 14mm
  • engage = angle - 8 degree; travel - 9mm
  • diagonal = range 20 degree; hitting 66%
  • force to engage = force to engage = 0,17kG
CLW304 - joystick on leaf switches. I think that this CRAP! :P
  • rotation = circle
  • engage = angle - 6 degree; travel - 7mm
  • diagonal = range 30 degree; hitting 80%
  • force to engage = force to engage = 0,22kG
CLW305 - very soft, very good diagonals, this very nice Crown model.
  • rotation = circle
  • diagonal = range 45 degree; hitting 90%
  • force to engage = force to engage = 0,175kG
CLW305 +Spring Action - for me this the best Crown model. I command him, it acts how hybrid Fanta and Competion. Good for KOF, Tekken. :notworthy:
  • rotation = circle
  • force to engage = force to engage = 0,2kG
CLW306 - NEW Crown model, Quality of realization very good! This looks beautifully. It acts to CLW305 similarly (but I still will CLW305).
  • rotation = circle
  • throw = angle - 12 degree; travel - 12mm
  • engage = angle - 8 degree; travel - 8mm
  • force to engage = force to engage = 0,275kG
manufacturers:
MyoungShin
Myoungshin
Fanta (low stiffness) - Fanta clone, the most often used in korea. Nice feel and realization. BUY:) Alter microswitches on Omron. Joystick acts on them magnificently!
  • rotation = circle
  • engage = angle - 9 degree; travel - 10mm
  • diagonal = range 25 degree; hitting 75%
Fanta (medium stiffnes) - Fanta clone, used in Saulabi. Fatal feel and realization, NOT BUY! battop is from rubber, bad centres to center, very slow joystick. CRAP!
  • rotation = circle
  • force to engage = force to engage = 0,37kG
manufacturers:
TaeYoung
TaeYoung
Fanta - original "Fanta". Japanes & Korean played on this joystick on SBO. It is very hard 0,5kG! Quality of realization very good - pretty and durable! Unfortunately when I played I lost diagonal during executing QCF:( Therefore that it is hard... Microswitches - GERSUNG very good!
  • rotation = circle
  • force to engage = force to engage = 0,5kG
I apologize for my English. MOD/Admin can edit & improve sentences ^---^
destructor
Re: Korean Joysticks
« Reply #1 on: December 23, 2007, 03:16:15 pm »
Excellent reviews :applaud:
PS. Wait for 4.5" trackball review from kowal :P
« Last Edit: December 23, 2007, 03:18:16 pm by destructor »
TOK
  • The Game Always Wins
« Reply #2 on: December 25, 2007, 09:27:45 pm »
Interesting sticks... The spot below the stick base and the dust washer -is that stationary?
Can you drill a hole in 3/4 or 5/8" MDF and bottom mount that or does that part need to be exposed?
kowal
  • Suzo 4ever
« Reply #3 on: December 26, 2007, 04:34:36 am »
panel can not fatter how 15mm
5/8'' I think that it will be OK
TOK
« Reply #4 on: December 26, 2007, 07:06:07 pm »
Thank you. I kind of like the way that pokes through the hole like that.
