Author Topic: Need help with converting image for use in MaLa  (Read 3412 times)
LeedsFan
« on: December 09, 2007, 04:16:52 pm »
OK guys I've been tinkering around with my MaLa instsall this evening with some success. I managed to get my original MameWah menu screen converted using the MaLa conversion tool (very clever) and to some degree all is fine.
However my original MameWah screen had a background image that I made myself over which MameWah put all the menu and image boxes. This image is saved as a JPeg file... exactly the same format as all the Space Invader background images used in MaLa as default. But I just cannot fathom how to get my image displayed.
The menu looks just the same as it did with MameWah but without my background image.  :dunno
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Need help with converting image for use in MaLa
« Reply #1 on: December 09, 2007, 04:34:08 pm »
Use the layout editor, MalaLayout.exe.  Below is the wiki instructions for setting the background image.  Its the second item under the heading "Building the layout".
http://wiki.arcadecontrols.com/wiki/Mala_Layout#Building_the_layout
loadman
  • Moderator
    • MaLa
« Reply #2 on: December 09, 2007, 05:04:10 pm »
FYI
The Mamewah layout converter does not 'automagically' copy the graphics over.
You need to do that manually.
LeedsFan
« Reply #3 on: December 09, 2007, 05:33:20 pm »
OK guys thanks for the help... I've got a bit further now. I can see my converted MameWah image in the MaLa editor. And I can import my background image fine. However I cannot get a "Title" box to appear anywhere. There is no Title box on the screen.... and selecting and deselecting in the text options list does nothing. I can bring in any other kind of text choice... except title.
And when I save my work and reload MaLa my background graphics are still not showing. Does my background art have to be in a certain place even after I've saved?
EDIT:   LOL... I've sorted out the image problem.... just wasn't in the correct directory. Still need to work on the Title box issue though.
LeedsFan
« Reply #4 on: December 09, 2007, 07:01:56 pm »
Well I've been at this for the last two hours now and I finally worked it out. Well sort of... I still never managed to get "Title" box to appear in my template. But I was able to select a user defined text box to sit in its place and then set it as I wanted. I'd been so focussed on the Title issue that I never thought to try one of the other lines.  :dizzy:
Time for bed... and somw more tweaking tomorrow. I must say as I get more used to MaLa it does look extremely flexible. I bet there must be some cracking FE templates have been made with this software.   :applaud:
loadman
  • Moderator
    • MaLa
« Reply #5 on: December 09, 2007, 08:20:11 pm »
