Author Topic: How do I make this cut?  (Read 3333 times)
crummy
  • Last login:May 11, 2008, 03:01:58 am
« on: November 25, 2007, 07:52:43 pm »
This seems so simple but when I try it I reach such difficulties. I'm making diagonal cuts, for the back angle of the cabinet for example, but I think I've reached the end of my woodworking skills.
Here's an approximation of the cut I'm trying to make:
I have a jigsaw (which I tried adjusting to make a 45 degree angle, but was unable to cut a straight line for the life of me), and a circular saw.
I'm pretty sure everyone must have made a cut like this at some point, so... any tips?
Re: How do I make this cut?
« Reply #1 on: November 25, 2007, 08:54:38 pm »
How long is the cut?  I'd use a radial saw if it's less than 12" or my tablesaw if it was longer.  If you only have a circular saw I'd make a sawboard at the same angle you are trying to cut and use it to cut your panel...  check the sticky at the top of this forum for instructions how to make one...
crummy
« Reply #2 on: November 25, 2007, 09:02:17 pm »
It's 30", I have to make several cuts for this.
I see the sawboard instructions, and I think I understand them, but I'm not sure how I'd make one at a 45 degree angle.
« Reply #3 on: November 25, 2007, 09:05:04 pm »
When you are cutting the sawboard to the proper length just use your circular saw set at 45 degrees.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #4 on: November 29, 2007, 10:20:58 pm »
Alternatively.... Use a 45 degree Router Bit..... Run the router along a guide and get it to make the angle for you.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
flybeasley
  • Last login:November 30, 2007, 12:52:40 pm
« Reply #5 on: November 30, 2007, 12:23:02 pm »
You can use a circulear saw. Set it for 45 and clamp a guide rail next to the cut.  Can even use a 1 x2  and screw it down and use that as your guide rail.
Love for all, hate no one, death from above.
fjl
  • Pixels Rule!
« Reply #6 on: November 30, 2007, 04:11:31 pm »
Best Regards,
Best bet.
Otherwise youd have to use a table saw.
whammoed
  • Last login:December 04, 2025, 12:20:55 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #7 on: November 30, 2007, 07:17:15 pm »
Best Regards,
Best bet.
Agreed.  Just did this recently to replace the bottom of my pole position.
I clamped a piece of wood to the piece I wanted to cut as close to the end as I could and still make a full cut with the circular saw set at 45 degrees.  I then used a saw board to cut it to size at the other end at 90 degrees.
