Author Topic: Happ Super  (Read 1271 times)
jstrange_1
  • Last login:May 12, 2003, 01:31:40 pm
Happ Super
« on: May 09, 2003, 01:12:15 pm »
I just recieved my Super Joysticks from Happ and am not sure about a part that was sent.  When I went to install the joysticks I used the plastic collars that came with the joystick (one is for wood and one is for metal), and both of the collars did not set flat with the CP.  I'm using 1/2" MDF and 1/4" plexiglass for my CP.  I have thought about just cutting these peices shorter, but wanted some advice from those who have done this before first.
_Iz-
  • Last login:December 03, 2025, 11:55:42 pm
  • Time to coin up!
Re:Happ Super
« Reply #1 on: May 09, 2003, 01:17:47 pm »
you shouldn't need to cut anything regarless of control panel thickness. Better check the exploded view on happs site to make sure you are assembling correctly.
jstrange_1
Re:Happ Super
« Reply #2 on: May 09, 2003, 02:47:40 pm »
One more question: does the black sleave suppose to cover the metal post of the joystick, or does it suppose to sit flush with the flat black washer.
Veto
  • Last login:May 21, 2003, 05:35:12 pm
  • GTG 3D in Mame soon please.
Re:Happ Super
« Reply #3 on: May 09, 2003, 02:54:29 pm »
Use the longer of the two sleeves.  Put that on the shaft first, then comes the round "washer."  Big end of the sleeve is up, next to the handle.
jstrange_1
Re:Happ Super
« Reply #4 on: May 09, 2003, 03:03:17 pm »
Thanks for the responses.  I'm now I little bit smarter and can move on with my CP.
