Author Topic: Touching up Melamine  (Read 2595 times)
OnigumO
  • Last login:July 07, 2003, 08:52:06 pm
« on: May 09, 2003, 06:22:01 am »
Hi, while working with some white melamine-laminated wood that I got at Home Depot, I got some chipping from the cutting that I did.  I wanted to know if there was any good way to touch it up, or if there are any products out their made for this purpose.  Thanks.
Kane
  • Last login:June 06, 2023, 08:05:47 am
  • What?
Re:Touching up Melamine
« Reply #1 on: May 09, 2003, 08:28:12 am »
When ever I work with melamine I make all my cuts 1/8" larger (because of the chipping) then I run my planner set at 1/16" over it twice. It leaves a perfect edge. I have not yet found a way to stop the edges from chipping, or a way to "repair" them if they do.
SirPeale
  • Green Mountain Man
« Reply #2 on: May 09, 2003, 08:41:36 am »
Make the side you want facing out face down, and cut with a tool that rips up.  This worked for me.
VMJ Team
  • Last login:July 09, 2007, 09:29:50 am
    • Virtual Music Jukebox
« Reply #3 on: May 09, 2003, 09:16:13 am »
You need an 80-tooth saw blade designed specifically for cutting melamine.
http://www.rockler.com/ecom7/showdetl.cfm?offerings_id=10538&objectgroup_id=406&catid=7&DID=6
