Author Topic: Applying CP artwork with flush mounted trackball plate  (Read 1603 times)
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« on: October 19, 2007, 10:17:36 am »
Ok I did search the forum for 20 minutes and didnt find what I wanted so here is my question :
How do you apply your artwork if you have a flush mounted trackball with the mounting plate ?
I guess you cut the trackball hole first in the artwork, install the mounting plate with the trackball then apply artwork ? (and go on cutting button holes, installing them etc...)
Also... any problem sticking the artwork on the trackball mounting plate ? I mean any deformation of some sort of the artwork there ?
Thank you !
Nataq
Re: Applying CP artwork with flush mounted trackball plate
« Reply #1 on: October 26, 2007, 03:57:12 pm »
K... i guess I answered myself. Thanks guys  ;)
