Author Topic: Looking for a "Aux Output Adaptor Board" for a blitz/showtime 2000  (Read 3641 times)
pkurz
  • Last login:December 03, 2007, 11:54:27 am
  Changing over a Dark Legacy and I am looking for this part, either to purchase or a wire diagram so I can make one or bypass it..  And if anyone has done this conversion, please contact me, because I need some help!!!!!!!!!!!!!!!!!!!!!!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Looking for a "Aux Output Adaptor Board" for a blitz/showtime 2000
« Reply #1 on: October 17, 2007, 05:32:00 pm »
Good luck finding one.  They're hard to find now. :(
I am curious about the I-40 Aux I/O adapter board too, as mame will need to know how they work before 49-way joystick support can be added to the games that used them.
And why the heck did the midway sports games need them but the atari 49-way games not? ??? Grrrr.
Sorry not much help.  All I can say is googling for them is like looking for a needle in  haystack, and happs, the company that bought midway's arcade parts and service division, doesn't seem to sell it online. :(
edit: Maybe happs does sell it.  Search for part # 04-12652.  ~$18.  :dunno
« Last Edit: October 17, 2007, 05:41:23 pm by u_rebelscum »
Robin
Knowledge is Power
pkurz
« Reply #2 on: October 17, 2007, 07:39:10 pm »
happ has the i-40 boards, that is where I got mine
pkurz
« Reply #3 on: October 17, 2007, 07:49:14 pm »
the aux out adaptor board from what I found out is nothing more than a wire bridge board, there is nothing circuitry on this board, a 20 ribbon cable connects this to the main board, then it goes to a 15 pin connections, and only 6 of the 15 are used to go to the i-40 board.  What I need to know is what wires from the ribbon cable is used, if someone has a blitz they could take a picture of this and post in on line....  Then you could really make your own.
pkurz
« Reply #4 on: October 17, 2007, 08:00:05 pm »
hey thanks, hopefully this is it.. I will let you know
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« Reply #5 on: October 18, 2007, 11:58:30 am »
is this board located in the CP?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: October 18, 2007, 01:15:17 pm »
Umm, pkurz, are there two or three of you?  Or is someone else also using your login?  You posts confuse me, but it could just me me. :dizzy:
Thanks for the info.  I had thought it had a chip and timing crystal on it?  I'd like to see how to make your own, too.
Is that part number I posted the correct one?  I might get one just to check it out.
I don't have a cab, but in the manuals it's a small board off to the side of the main PCB.
Robin
Knowledge is Power
