Author Topic: Stereo receiver very close to touch screen monitor -- Problem???  (Read 1368 times)
unclet
Building a jukebox cabinet right now and before I start screwing everything together, I wanted to ask people whether they believe placing a stereo receiver right underneath a touchscreen monitor would be a bad idea.
The space requirements I am dealing with are not a lot so the best place for my stereo receiver (if it is to sit flat like normal) is to rest it about 1 inch under the touchscreen monitor.   Would there be any problem with having the receiver so close to the monitor?
I guess my only other solution would be to mount the receiver on it's side somewhere else in the cabinet.   Would this be a bad idea or cause the receiver any harm to have it always be sideways?
Re: Stereo receiver very close to touch screen monitor -- Problem???
« Reply #1 on: October 17, 2007, 09:10:40 am »
Interesting question... I'd say put it there and if you see issues, shield it.
unclet
« Reply #2 on: October 17, 2007, 09:49:55 am »
Yeah I just thought about this and I am at work so I can not simply test it out until I get home.  Even if it does not result in any interference right away I was wondering whether there would be any effects I need to worry about over a long time period into the future.
How about positioning a receiver on it's side ..... will this work or would that be bad for the receiver?
Also, last time I asked about speakers and such I believe "shielding" came up and I thought buying true shielding material was too expensive.
« Reply #3 on: October 17, 2007, 09:57:48 am »
You can shield with most simple metal, IIRC, so long as it is thick enough.  I have shielded cocktail power supplies (that were too close to the monitor) with coffee cans.
If the receiver has no moving parts I can't see putting it sideways as a problem.
