Author Topic: Mortal Kombat 1 Jamma board  (Read 1392 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: October 14, 2007, 03:45:51 pm »
Hey all.
I bought a MK1 board for $9 dollars.  It was advertised as NON working / glitchy.  After a few shorted pins were fixed and bad solder joints redone, it works great.
Only one problem.  I am having some issues with the sound board.
I only had the ribbon cable, no other wiring.  After making my own wiring harness for the sound / power connections from JP2 on the cpu board, I still didn’t receive any sound.
I found out shortly after that it was just inaudible sound and that i needed a volume pot for the sound board.
After hooking that up i did indeed get sound.  Trouble is...  I only get SOME sounds.  It seems as if all the vocal sounds are missing.  I only receive music, tones and some selection menu effects.
Iv been threw the diagnostic tests and everything checks out (ROM checks / one tone).  Also, the sound effects testing, i only hear music effect that play, no vocals.
Any of this sound familiar ?  Any suggestions are appreciated  ?
Arm123
Re: Mortal Kombat 1 Jamma board
« Reply #1 on: October 14, 2007, 04:32:12 pm »
Ok...   I 'think' i found the problem.
It looks as if someone removed IC U32 off of the sound board.  Its a tl084, and i guess i need to find a replacment.
Arm123
Re: Mortal Kombat 1 Jamma board [FIXED]
« Reply #2 on: October 15, 2007, 07:45:05 pm »
I replaced that that TTL and ALL sound works fine now.  Hope this helps someone...  But then again, i dont know who the hell would remove a chip off a perfectly good board.
