Author Topic: Werid Scrolling Effect on Vertical shooters?  (Read 2543 times)
lettuce
  • Make It So!
« on: September 09, 2007, 10:00:40 am »
Have recently notice a strange effect in the scrolling on vertical shooters and some horizontal (games that stick in my mind are Tiger Heli and the Real Ghostbuster). Where the back ground in this case the actaul floor seems to be split up in 7 or 8 strips going across the screen and each of these strips seems to scroll independently to each other. Im probably not making much sense as its really hard to explain the effect, but its kind of like if each of these strips going across the screen is its own screen and then there all stuck together to make the whole display up, much like a video wall i guess. Does anybody have any idea what im talking about and why this is happen??
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
Re: Werid Scrolling Effect on Vertical shooters?
« Reply #1 on: September 09, 2007, 11:29:45 am »
Sounds like screen tearing. Try creating seperate ini files for those games and enable triblebuffer.
My old user name was marlborroman13, but I kicked the habit many years ago!
lettuce
  • Make It So!
« Reply #2 on: September 09, 2007, 12:40:23 pm »
Nah its not screem tearing, its kind of like a 'Mode 7' effect that the snes used to do
BobA
  • What Me Worry?
« Reply #3 on: September 09, 2007, 02:23:25 pm »
Whether it is tearing or not the effect is usually lessened  with triple buffering.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: September 09, 2007, 06:13:01 pm »
Mode 7 was screen rotation. I really doubt you're talking about graphics rotating.
I've never seen the problem you're describing. Try taking a screen shot and see if the problem shows up in the screen-shot.
NO MORE!!
TOK
  • The Game Always Wins
« Reply #5 on: September 09, 2007, 07:14:19 pm »
I've noticed a scrolling effect similar to that description in Xevious. Doesn't seem to be as pronounced as the problem you're experiencing, but noticeable enough that it came to mind as soon as I read your message.
I haven't caught it in other games, and wondered if it was the way Xevious actually scrolled. Doesn't seem as smooth as I remembered it, but its been over a year since I've played a "real" Xevious.
Zebidee
  • Trade Count: (+9)
  • Last login:February 07, 2026, 01:57:20 am
« Reply #6 on: September 10, 2007, 01:33:48 am »
For games like xevious & R-type, you need triplebuffer off (triplebuffer 0).  But on some like Wonderboy, you must run it on or the game is unplayable (for me).
Other thing it could be is the h/ware acceleration from your video cards.  Some have a problem with the way they tile images on the screen, which could be what you are looking at  :dunno  You can try looking at your video card settings.
Need more data!  video card, software, ini files etc ....
lettuce
  • Make It So!
« Reply #7 on: September 10, 2007, 12:48:34 pm »
Ok more info, im using an AGP AvrcadeVGA card, and using Directdraw rather than Direct 3D, (as this is the way your surpossed to setup mame to use the ArcadeVGA card). No hardware stretching or triplebuffe. Ill try and get some picks later but not sure if it will show that well in stills need to be moving to notice it i guess. Have also notice it in Undercover cops, when your character moves across the screen looks like the same effect. A good thing to compare it to is the Mode 7 effect that the Genesis/Megadrive try to do in the last few years of its production, manly in contra Hard Corps, the mid level boss on the 1st level kind of has the same effect on him, guess this will only be useful to people who have actuall played this game or had a MD or Genesis
lettuce
  • Make It So!
« Reply #8 on: September 10, 2007, 02:23:58 pm »
Ok think ive pin pointed the problem, if you press the '`' button when a rom is playing which brings up the volume control, you can scroll down and changed the picture, one of the options for stretch horizontal was changed from the default setting, i changed it back and it stop the scrolling problem, only think is now the game display is seriously overscanned  :banghead:. Cant understand why stretching the picture would cause a scrolling problem  :dunno
RayB
  • There's my post
    • RayB.com
« Reply #9 on: September 10, 2007, 04:08:46 pm »
MODE 7 was the SNES's background scaling and rotation mode! Read my post above!
Perhaps you're talking about PARALLAX scrolling where the screen is split into different strips horizontally, scrolling at different speeds???
NO MORE!!
