Author Topic: How can you tell the difference between old Midway 49 and new Happ 49?  (Read 1279 times)
gatordad
  • Trade Count: (+11)
  • Last login:December 12, 2025, 11:50:05 am
I have 4 Midway 49 way joys (don't know if its happ or old Midway) that I just cleaned up with perfect grommets no tears or anything.
I measured the shaft with a ruler and ithey are approx 1/4 in wide.
How can you tell if this is the new Happ 49 way or the older Midway one.
Is there any replacement sticks (balltops) for the ones with 1/4 in shaft or any other way to get balltops on one?
GD
« Last Edit: September 10, 2007, 09:14:27 am by gatordad »
gatordad
Re: How can you tell the difference between old Midway 49 and new Happ 49?
« Reply #1 on: September 10, 2007, 09:15:24 am »
bump
Anyone?
markrvp
  • NFL Expert
« Reply #2 on: September 10, 2007, 11:43:50 am »
The Midway shaft diameter is larger than the Happ.  I don't have the measurements off hand.  They look identical, but the shaft diameter is the difference.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: September 11, 2007, 12:52:48 am »
There was a thread on this within the last month or two if you go searching.  I think what it came down to is that:
There are replacement shafts for the Happ variety at GGG.  If you've got the Midway there are no replacement shafts available.  In that case you can try swapping out the actuator and grommet in order to fit the GGG handles.
