Author Topic: noob alert ! need help with DOScab  (Read 12126 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: August 28, 2007, 01:16:14 pm »
hey,
been playing with WINcab for a while now on my XP machine and think its great :D and was planning on shifting it to my windows 98 (dos mode) PC with arcadeos, mame, and DOScab. only problem being is DOScab doesn't show the music! it loads you can through the keyboard tap the buttons but shows no music
im gunna play with it later so might be able to shed so light on it
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: noob alert ! need help with DOScab
« Reply #1 on: August 28, 2007, 01:20:03 pm »
Remember you are no longer in the world of long filenames, so check your SongPath and make sure it conforms to what DOS supports.
--Chris
--Chris
david656
  • Big Man!
« Reply #2 on: August 28, 2007, 01:30:38 pm »
c:\music
is taht too long !?!?!?!?
and thanks for the reply, could it be down to the fact i was trying it on my xp machine, basicly my DOScab HDD is in THIS pc and on boot up i boot from it to see if all the music copied over etc before sticking it back in its proper cab, so could it be that theres no soundcard installed
btw i am totaly new to DOS really ! i have got ARCADEOS to play a few SILENT games and liked WINcab but im guessing i have to load up things before DOScab for it to work in dos? because in windows 98 DOScab does show the music
Chris
  • Moderator
« Reply #3 on: August 28, 2007, 01:36:03 pm »
Can you set DebugLevel=4 in JUKEBOX.INI and run DOSCAB  and send the resuting jbdebug.log file to celamantia@charter.net?
--Chris
--Chris
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 28, 2007, 09:55:23 pm »
Can you clarify that a bit?
So it loads up ..... and you can use the keyboard ..... but nothing happens at all?
Or does it play just fine but you just can't SEE it happening?
I guess if you don't have a sound card installed you wouldn't know for sure it was playing at alll though.
I ask because I had a similar problem where it played just fine but nothing showed up. (just couldn't see it)
It was the video card drivers.
Just thought I'd throw that out there.
david656
  • Big Man!
« Reply #5 on: August 29, 2007, 11:12:17 am »
humm all fun !
i got a NVIDIA video card its either
NVIDIA RIVA TNT
NVIDIA RIVA TNT2
can't remember ! but it seemed to work fine etc but when i took it out and used the onboard video card (which i haven't installed the drivers for yet) i got sound in windowsthrough BOTH speakers and with about 5mins of tinkering MAME, ARCADEOS and DOScab ALL have sound from the onboard AC '97 !!!!!
only promblem is its a bit crackly, any idea's on how to solve this AND how do i loads the sound drivers in DOS??
thanks a lot
Chris
  • Moderator
« Reply #6 on: September 01, 2007, 04:35:27 am »
Did you send that log file?  For DOS, a copy of your autoexec.bat and config.sys would be useful too.
--Chris
--Chris
david656
  • Big Man!
« Reply #7 on: September 03, 2007, 05:06:27 pm »
ahh sorry bout not getting back went on a short holiday am back now thou !
heres the latest
i've had enough of the mucking about and bought a SB 16 PCI on eBay !
so the basics are:
i've been mucking about with all the things aka 'autoexec' and 'config.sys' etc and deleted the config.sys and bodged a few things !
im also noticing that 98 boot to dos before 98 loads is a pain, how can i get raw DOS? i have 7.10or .11 and its discusting a totaly bisare instalation and bugs me. i have 6.22 somewhere and remember installing it last year and it worked quite well, but at the minute don't have a foggyest where the disks are :S
Chris
  • Moderator
« Reply #8 on: September 03, 2007, 11:23:17 pm »
heres the latest
so the basics are:
There's a system file in the root folder called msdos.sys; edit this and set BootGUI=0.  You may want to set Logo=0 too.
--Chris
david656
  • Big Man!
« Reply #9 on: September 04, 2007, 06:14:13 am »
sorry should of been clearer ! thats what i've got, but i want actual dos not 98 dos. jusyt to clear that up
Chris
  • Moderator
« Reply #10 on: September 04, 2007, 09:20:24 am »
With BootGUI and logo turned off, Windows 98 DOS is just plain DOS 7.1.  You could also try FreeDOS at http://www.freedos.org/ ; I haven't tested it with DOSCab but it should work.
--Chris
david656
  • Big Man!
« Reply #11 on: September 18, 2007, 05:24:33 pm »
hi Chris i have poped you a email of my log and hope to hear from you soon
david656
  • Big Man!
« Reply #12 on: September 20, 2007, 02:37:09 am »
chris haven't got a email back from you. did you get mine?
Chris
  • Moderator
« Reply #13 on: September 20, 2007, 03:01:57 pm »
I got it, I've just been swamped.  I'm guessing that this is the CWSDPMI conflict.
Go get http://www.japheth.de/Download/HXRT.zip and extract HDPMI32.EXE from the Bin directory.  Run that before running DOSCab or any front-end that calls DOSCab.  Does that help?
--Chris
--Chris
david656
  • Big Man!
« Reply #14 on: September 22, 2007, 10:04:22 am »
well if i try and load that file  like this
autoexec.exe
(soundblaster things)
(if i put it here it freeses)
cd c:\arcade
arcadeos
(if i put it here dos cab doesn't load)
cd c:\Jukebox
doscab
_________
when i try and load it through DPMILD32.EXE it says file misssing, not sure what its missing but it is
this is just a thought BUT when i extracted DOS from Windows 98 HDD there was a long list of MISSING files that didn't get put on the floppy's but i didn't think nothing of it, could that be what its missing?
david656
  • Big Man!
« Reply #15 on: September 24, 2007, 11:42:19 am »
hello chris ?
david656
  • Big Man!
« Reply #16 on: October 24, 2007, 02:06:07 pm »
bit of a twist ! i got naffed off with DOS and have moved with the times to a XP mameWAH setup. now as it is mame (commandline) is dead slow i mean all games are chugging along at a extremly slow rate !
its a AMD board with 256mb ram and bout 2. summit Ghz CPU
on my main home PC wincab loads a treat as soon as i shuv it on this AMD piece of crap it sort of loads a windowed black box with the name wincab at the top, the thinking light flashes away and the HDD weerss away, so its obviously updating the song list BUT nothing happens with the screen except for this windowed box !
i really hope you can tell me why its doing this, i do like your jukebox software and want to use it, but am getting naffed off at how un pridictable Windows can be ! the PC is set up so page fileing (what ever that is) is on another partition,
i hope you can help :D
thanks david
Chris
  • Moderator
« Reply #17 on: October 24, 2007, 02:31:07 pm »
This usually means that WinCab has been asked to run in a resolution that's not supported by the video driver.  The screen should still come up, though.  Check jukebox.ini and try a fairly universal resolution like 640x480 or 800x600 and see if that gets anywhere.
--Chris
--Chris
david656
  • Big Man!
« Reply #18 on: October 24, 2007, 02:43:25 pm »
Chris,
you'll neva guess what ! it was the onboard video it just didn't like it, so i got out a AGP graphics card the NVIDIA TNT 2, and it loved it !! :D :D
 :notworthy:
so yup, and also i loaded WINcab in seconds i nearly fell over amazed at the speed ! so maybe MAME will get fater now !
one last thing, can i run WINcab from mameWAH?
thanks Chris
david
Chris
  • Moderator
« Reply #19 on: October 24, 2007, 08:35:04 pm »
Yes.
--Chris
david656
  • Big Man!
« Reply #20 on: October 25, 2007, 09:52:08 am »
Chris
  • Moderator
« Reply #21 on: October 25, 2007, 10:19:52 am »
See http://wiki.arcadecontrols.com/wiki/Mamewah_Other_Apps for information on how to use MAMEWah with external Windows apps.
--Chris
david656
  • Big Man!
« Reply #22 on: October 29, 2007, 05:44:04 pm »
can you spell it out to me by copying and pasting a working set of ini things because i have spent days trying to do it and STILL it won't work
thanks
