Author Topic: Speaker HELP  (Read 1601 times)
SUPER_SSII_TURBO
  • Last login:September 17, 2007, 01:33:52 pm
Speaker HELP
« on: August 16, 2007, 10:20:58 pm »
Hi I have a Mortal Kombat 4 Jamma cab.  I want to throw in an amplified speaker system...But how the heck do you wire it up...Pc speakers use a typical headphone jack....and the out put from a jamma connector is just + & -....any help would be awsome thanks. :applaud:
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: Speaker HELP
« Reply #1 on: August 16, 2007, 10:44:52 pm »
I think if you did a google search, you'll be able to find which wire is +/- on the speaker wires.
SUPER_SSII_TURBO
Re: Speaker HELP
« Reply #2 on: August 17, 2007, 02:06:16 am »
thanks...but i already know what wire is pos+, and neg_,,,i need someone to help with how in the world i turn that into a compadible connection with a set of pc speakers...i know i cant be the first on to want to do this...thanks
genesim
  • Last login:April 12, 2010, 08:18:42 pm
Re: Speaker HELP
« Reply #3 on: August 17, 2007, 03:23:51 am »
Its pretty simple if the line isn't amplified...just get at converter that goes to minijack and cut off the RCA ends and splice it to the respective positive and negative.
If it is amplified, then run it to a speaker box that radio shack sells where it takes an amplified line and converts it to rca.   Then just get some couplers to run it to minijack. ...though you will most likely get hiss.
Or of course just download it and forget the PCB. ;D
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Speaker HELP
« Reply #4 on: August 19, 2007, 11:10:17 am »
JAMMA expects an amplified line, so ignore the first response, unless you are converting to something with an unamplified line.
As for the second response, let's slow down ... SUPER_SSII_TURBO -- what are you trying to do ? (e.g. why are you putting amplified PC speakers in a JAMMA cab).
I am thinking that there may be a better way to accomplish your goals than what you are suggesting.
EDIT: Obnoxious troll remark removed ... but I did say it.  >:D
« Last Edit: August 20, 2007, 07:23:13 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
infamous360
  • Last login:May 30, 2008, 11:27:04 pm
Re: Speaker HELP
« Reply #5 on: August 19, 2007, 12:53:58 pm »
you can use a home stereo system and a y-audio cable  to convert the white and red to a headphone jack
thats what i did and it sounds great
Current projects: IIDX Doubles Deck, Playstation2 joystick, Xbox360 Joystick
genesim
Re: Speaker HELP
« Reply #6 on: August 20, 2007, 05:49:45 am »
CheffoJeffo,
What the hell is your problem?
First you start coming in and personal attacking me on a thread....then you start PMing me.   What are you anyway a frickin' stalker?
I was simply trying to give some help and you offer absolutely NOTHING to the thread.
Come up with a suggestion and help the poor guy out instead of acting like a complete tool.
CheffoJeffo
Re: Speaker HELP
« Reply #7 on: August 20, 2007, 07:12:19 am »
What I was getting at with my question to the OP was to find out if he is just trying to boost the volume of his MK4 boardset or if he is wanting to convert to a PC-based system or if he is wanting to go with a system that is swappable between JAMMA and PC.
The best solutions for each may be different since PC audio is typically unamplified stereo and JAMMA audio is amplified mono and, while everybody is happy to help with connectivity issue, I see the more important issue as proper amplification for decent sound quality. The actual connection is secondary.
« Last Edit: August 20, 2007, 07:50:54 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
