Author Topic: glaunch skip warning on roms  (Read 3136 times)
hunty3000
  • Last login:November 26, 2010, 07:12:37 pm
« on: August 11, 2007, 03:09:57 pm »
hi, i running glaunch and mame32 on my cocktail cab. its all set up with just a few games on. the only thing what is annoying is the warning message on the start of galaga. there is a script for glaunch to run cmd's before the game, ive tried -skip_warning and it doesent work. is there anything else i can put or will i have to set it up with a new emulator like nonamemame or advmame.
BobA
  • What Me Worry?
Re: glaunch skip warning on roms
« Reply #1 on: August 11, 2007, 04:56:50 pm »
You can set skipgameinfo and skipdisclaimer to 1 in mame.ini BUT only if you have an older version of MAME that supports it.   Newer versions of mame do not have this option.   I am using .73 and it works fine.
fjl
  • Pixels Rule!
« Reply #2 on: August 11, 2007, 05:01:04 pm »
I noticed that. Why did they remove the option to skip those disclaimers?
BobA
  • What Me Worry?
« Reply #3 on: August 11, 2007, 08:19:50 pm »
Must have been "politically motivated" because it does not affect the emulation at all.   Sort of like why are gambling games back when they were removed earlier?
hunty3000
« Reply #4 on: August 12, 2007, 01:03:36 pm »
thanks for the help, ive put mame32 .73 on but galaga dosent work its missing roms. has any one got a version that works with .73, if u have could you please email it to me thx. hunty3000@msn.com
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #5 on: August 12, 2007, 03:45:27 pm »
Why not just create a custom compile of mame to remove the nag screens. This way you can use a newer version of mame. Do some searching and you can find instructions for this.
My old user name was marlborroman13, but I kicked the habit many years ago!
hunty3000
« Reply #6 on: August 12, 2007, 04:49:05 pm »
to much messing about, its all set up again now. easer to just get the right galaga version.
hunty3000
« Reply #7 on: August 12, 2007, 05:42:11 pm »
got a working version of galaga and edited the config file but it still comes up. any suggestions.
skip_disclaimer          1
skip_gameinfo           1
BobA
  • What Me Worry?
« Reply #8 on: August 12, 2007, 05:48:39 pm »
You have to use a mame binary not mame32
hunty3000
« Reply #9 on: August 12, 2007, 06:08:17 pm »
yeah thats what im using now but still carnt get it to work
BobA
  • What Me Worry?
« Reply #10 on: August 12, 2007, 06:17:40 pm »
If it gets rid of the other 2 screens then that is probably all you can do without recompiling.   The last message is not covered by the flags in the mame.ini
  • Last login:October 17, 2025, 10:29:23 am
« Reply #11 on: August 12, 2007, 06:23:23 pm »
Add
ftr 1
to your mame.ini
ARTIFACT
« Reply #12 on: August 12, 2007, 09:19:32 pm »
AMDman13
« Reply #13 on: August 12, 2007, 10:52:25 pm »
If your not ready to creat your own custom recompile than I would suggest noname mame by byoac'er TheGatesOfBill it can be found here https://sourceforge.net/project/showfiles.php?group_id=91067&package_id=95932
It supports up to version 0.84u1
It supports no nag screens ultimately!
