Thanks for the application, it's very useful. I have a question for the group, maybe someone can help me:
I'm running Mamewah FE as a shell. I can't seem to get CabVol to start when the computer boots. When I exit Mamewah to explorer, then CabVol starts when the desktop loads (and stays running for future sessions of Mamewah) but it won't load on startup. I've tried putting a shortcut in the startup folder (which is where it is now) and also tried loading it via Mamewah, by entering the executable path in the 'applications to run on startup' entry in the mamewah.ini file. No luck.
What am I missing? I'd really like to use the application for volume control, but if I can't get it to go on startup, I'll have to seek other options. I don't really want to go away from mamewah as a shell, b/c this cabinet will be placed in a family member's bar, and requires the ability to 'fix things on reboot.'
I can get VNC to start up properly on reboot (because I can log into the cab remotely whenever it reboots), so I know that I should be able to get this program loading at startup.
Any suggestions?
