Author Topic: Got my die hard cabinet... doesnt fit in the door .. sigh  (Read 2871 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« on: August 03, 2007, 10:22:55 pm »
Well my die hard cabinet is abnormally sized and does not fit through either outer door in my home. going to have to attempt to dissemble it :angry:
« Last Edit: August 03, 2007, 10:25:01 pm by Peale »
pgifford
  • Last login:November 07, 2007, 11:25:32 pm
  • I'm a llama and lloving it!
Re: Got my die hard cabinet... doesnt fit in the door .. sigh
« Reply #1 on: August 03, 2007, 10:45:09 pm »
Bummer.  Why not build an addition on to your house that surrounds the cab?
Paul
torez
  • Last login:December 20, 2009, 09:40:12 pm
« Reply #2 on: August 03, 2007, 11:04:26 pm »
You don't have any oversized windows?
Hmm, why not cut a hole in the wall of the house and make the cab "built in"?  ;D
Official Omega Race WR Holder:
1 credit:  3,847,350
2 credit:  4,823,750
mrserv0n
« Reply #3 on: August 03, 2007, 11:31:46 pm »
We just been playing on the back porch lol. I do have a window but brother wont let me take it apart, might do it when hes not home.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #4 on: August 04, 2007, 01:23:11 am »
Does any part of the plastic shell come off?
I almost bought one of those cabs at a recent auction. I wondered at the time how tough it would be to move around.  If I would have had a way to get it home, I would have had a $10 Die Hard cab and probably have had the same trouble you are having.
t8erbug
  • Last login:November 28, 2008, 02:33:41 am
« Reply #5 on: August 04, 2007, 01:35:25 am »
How much to narrow is the doorway? Could you take out the door frame and get it in? If you pull the trim around the door and run a saws-all around the frame. It should release the frame in one piece and then you could just nail it back in. Had to do it once for a cabinet.
Austin.Wolff
  • Last login:February 04, 2011, 03:53:32 pm
« Reply #6 on: August 04, 2007, 01:37:21 am »
How sad :(
mrserv0n
« Reply #7 on: August 04, 2007, 02:37:27 am »
T8erbug, Yea it would JUST squeeze in if I removed the door frame, but its not my house I just rent a room so im not allowed to remove his door frame.
I could take the walkout basement window out when noones home and get a buddy to throw in there but then it would be trapped in the weight room with the same problem haha.
I have to believe the cabinet can be disassembled. Its a really strange plastic cabinet. I just need a extremely powerful drill to get out the rotten screws.
It sits on a 34" metal pad that looks like it was built to the bottom of the cab to never come off, could be wrong but there are 4 large iron rods coming out the bottom welded in there.. tommrow in the daylight ill have a better look at how its put together... hope she doesnt get too lonely out there :(
« Last Edit: August 04, 2007, 02:41:07 am by mrserv0n »
t8erbug
« Reply #8 on: August 04, 2007, 02:44:22 am »
On the screws, if they wont back out you can usually use a drill bit half the diameter of the head to drill just deep enough for the heads to pop off. After you take the panel off you can use a pair of pliers to remove the rest of the screw.
mrserv0n
« Reply #9 on: August 04, 2007, 11:13:15 pm »
I was able to pretty easily disassemble the cab in just 2 pieces with 8 screws and fit it into my door! Time to clean in up and I will post some pics!!  ;D
torez
« Reply #10 on: August 05, 2007, 12:43:18 pm »
Hehe, it should be actually easier to clean it while it is disassembled.  Lucky you  ;D
1 credit:  3,847,350
2 credit:  4,823,750
vintagegamer
  • Last login:October 26, 2025, 06:07:31 pm
  • Seasoned Arcade Survivor.
« Reply #11 on: August 05, 2007, 02:24:46 pm »
Man it sounds like you're starting to have the luck I've lived with for over 30 years..   :(
Hope you get it inside before the rain!!!
VG
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #12 on: August 06, 2007, 01:23:40 am »
I hate trying to get cabinets into my basement.  When I got my millipede I checked to make sure it would fit and everything but I forgot that people take up space also.  So nearly a broken hand latter and a few people we got it down.
17 years old and totaly addicted.
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« Reply #13 on: August 06, 2007, 08:34:33 am »
There were a number of reasons I wanted to build my cab from scratch, and not dealing w/ this kind of problem was definitely one of them...
(Ended up carrying all the pieces to the basement first then
assembling it there)
The other main reasons?
> didn't want to hack a good old cab
> wanted the experience (pride?) of building it myself
The con's?
> No "original" cab (yet, heheh)
> More expensive?  In looking at some of these posts
   you guys are getting amazing cab finds.  Bravo.   :applaud:
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #14 on: August 06, 2007, 12:42:24 pm »
This should solve your problem.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #15 on: August 06, 2007, 01:17:13 pm »
I heard mention of some rusted or rounded phillips, and i have a solution.  Most of the time a square head bit will fit in perfect and remove said stripped screw.  I've had to do that on a number of occassions when some knuckle head did that.
Chris G
« Reply #16 on: August 06, 2007, 03:21:34 pm »
It's a Die Hard cab... couldn't you have gotten it inside through the ductwork?   :dizzy:
torez
« Reply #17 on: August 06, 2007, 04:08:18 pm »
I bet you said "Yipee-kay-yay mo..." when you finally got the cab in  :laugh2:
1 credit:  3,847,350
2 credit:  4,823,750
« Reply #18 on: August 06, 2007, 05:50:38 pm »
Yes, but he can only get it up to the roof to throw it off.
