Author Topic: Modded Xbox for MAME arcade  (Read 2801 times)
tophatne1
  • Last login:January 09, 2016, 12:05:15 am
« on: July 31, 2007, 03:24:41 pm »
Is anyone running their arcade with a modded Xbox? If so what are you using for an encoder? I have seen the DIY ones from x-arcade but they don't have trackball support. A trackball i s a must for me.
I know a PC would be better but I already have the xbox.
unclet
Re: Modded Xbox for MAME arcade
« Reply #1 on: July 31, 2007, 03:33:00 pm »
Aren't old PC's pretty much cheap/free now and days.   You probably can fine people you know who might have an old Pentium 3 in the closet.
rooterman
  • Last login:November 10, 2013, 03:26:03 pm
« Reply #2 on: July 31, 2007, 03:52:13 pm »
I did one a few years ago using an x-arcade, but trackball support isn't there. You can use a keyboard and mouse adapter, but it really doesn't work well for trackballs. Right now I'm building a new cab with a pc so I can have a trackball, pinball sims, and a spinner. Also mame is not updated very often on the xbox, so some games aren't totally emulated, sounds not working mostly. I'd recommend using a pc.
r
Grasshopper
« Reply #3 on: July 31, 2007, 03:53:57 pm »
I've been using MAMEdox on my Xbox and it's awesome. In my opinion a modded Xbox is the best platform for running MAME on a TV.
However, if you're using a monitor in your cab then I'd say a PC is preferable as they're more flexible, generally faster, and can handle multiple display resolutions.
With regards to encoders, from what I've been reading MAMEdox will work with a USB keyboard although I haven't actually tried it yet. So theoretically you could use an Ipac. I'm not sure about mouse/trackball support though.
Green Giant
« Reply #4 on: July 31, 2007, 03:56:51 pm »
Have yet to see anyone use an xbox in a standard cab.  They are used more often on driving cabs using xbox controls.  If you are gonna use an xbox for a cab, make it a driving cab.
Toxic Arcade, my first build
rooterman
« Reply #5 on: July 31, 2007, 03:58:20 pm »
I actually have one on the drawing board, it's up next after I finish the pc cab.
r
« Reply #6 on: July 31, 2007, 04:03:14 pm »
Ive seen 1 GOOD one:
http://forum.arcadecontrols.com/index.php?topic=67656.0
and one NOT so good one:
http://www.myspace.com/arcadecabinet
Green Giant
« Reply #7 on: July 31, 2007, 04:03:26 pm »
A driving cab or standard cab using an xbox?
If it is driving, document it alot.  I eventually want one when I get a house.
Green Giant
« Reply #8 on: July 31, 2007, 04:06:34 pm »
That defeats the purpose of using mame though.  I think you could have a badass cab using an xbox and just xbox games, but to use it for mame specific would be a waste.  Playing MK Armagedon and some Samurai Warriors would be lots of fun on an arcade.  One of these days I might drop my xbox in a cab, but it will probably be for driving.
tophatne1
« Reply #9 on: July 31, 2007, 04:14:01 pm »
Wow! That was a lot of replies in a short time.
I like the look of the capcom one that was linked. Still no trackball though. I was over at x-arcade looking at the tankstick and some reviews of it on some sites. Apparently you can use a usb to Xbox adapter for the trackball but I don't think you can have the trackball usb adapter and the regular joystick adapter hooked up at the same time.
A driving cab is an interesting idea.
« Last Edit: July 31, 2007, 04:21:48 pm by tophatne1 »
tophatne1
« Reply #10 on: July 31, 2007, 04:16:30 pm »
I was looking at the Xbox as a MAME/Xbox game solution so I could play the Xbox fighting games without any of the slowdowns that I would have if I was using a Pentium 3 etc for a PC.
rooterman
« Reply #11 on: August 01, 2007, 06:04:39 pm »
I just posted my plans for my (yet to be built) xbox cockpit here:
http://forum.arcadecontrols.com/index.php?topic=69581.0
r
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #12 on: August 02, 2007, 03:09:49 am »
I've been pretty impressed with how well MAMEoX works on my soft-modded Xbox. Unfortunately there's little-to-no mouse support. USB keyboards work fine and are the only way I've found to get into all the options for MAME. Doesn't an I-Pac get detected as a standard USB keyboard? I'd think it would work fine.
The biggest stumbling block on an XBox is the 64MB of ram.
My setup works well when we want to play 4-player or just sit down and play in the living room, but I'm not sure it's good enough for an all-purpose sort of cabinet.
