Author Topic: notching MDF for t-molding  (Read 4079 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: July 28, 2007, 08:01:37 pm »
Whats the best way to notch the MDF for T-molding? Is there a tool that works pretty good?
BobA
  • What Me Worry?
Re: notching MDF for t-molding
« Reply #1 on: July 28, 2007, 09:53:28 pm »
A slot cutting bit used with a router.   Sized for your specific t molding.
http://t-molding.com/store/home.php?cat=6
Slot cutter blade and arbor required.
Chris G
  • Last login:April 16, 2023, 04:39:59 pm
« Reply #2 on: July 29, 2007, 09:07:11 pm »
Whiteside is the way to go, but you can get them cheaper at Holbren...
Cutter
Arbor
Use woodnet10 code to get 10% off.
BORIStheBLADE
« Reply #3 on: July 29, 2007, 11:24:06 pm »
Thanks for the help guys. Do you think they make them for Dremels?
BobA
  • What Me Worry?
« Reply #4 on: July 29, 2007, 11:32:11 pm »
A dremel does not have enough power to drive a slot cutting bit safely.  Some people have tried to use a dremel with a router attachment to cut slots but I do not remember one posting that was a real success because the bits on the dremel are not the same as a router slot cutter.
« Last Edit: July 29, 2007, 11:34:29 pm by BobA »
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #5 on: July 30, 2007, 11:26:59 am »
also trying to keep it steady would be quite interesting.  Even a cheaper router would be better than trying to use a dremel for this type of job.  I went cheap and brought a ryobi one from home depot for 59 bucks and it more than pay for itself.
And the bit above are nice ones.
Green Giant
« Reply #6 on: July 30, 2007, 01:18:12 pm »
An even cheaper option would be to get a noname crap one off ebay.  Picked one up for like 35 shipped for my cab.  Actually lasted much longer than I expected.  Finished the cab and it still works great.
A dremel should have the power to cut the mdf, but you would need some sort of mount or holder to make it work.  Also, I don't think you can get slot cutter bits for a dremel.  If you could make a mount to control the depth of the cut and attacht the bit somehow, it would work.
Toxic Arcade, my first build
Kaytrim
  • I'm too nice a guy
« Reply #7 on: July 30, 2007, 03:10:06 pm »
If you don't want to go to the expence of buying a router and slot cutting bit do what another member here did.  Cut off the 'T' portion of the molding and using contact cement, glue the molding onto the cab.
TTFN :cheers:
fjl
  • Pixels Rule!
« Reply #8 on: July 30, 2007, 09:16:32 pm »
You can also try renting a Router.
BORIStheBLADE
« Reply #9 on: July 31, 2007, 09:22:45 pm »
I was just thinking today.... my neighbor is a carpenter :banghead: I don't know why I haven't thought abought this sooner. If He has a router I can get him to do this.
I'll go buy the bit and have him do it then.
BobA
  • What Me Worry?
« Reply #10 on: August 01, 2007, 08:19:09 am »
He probably has the arbor too if he has a router and set of bits.  Maybe check before buying the bit.  You might get away with just the cutter or he might even have that.
Chris G
« Reply #11 on: August 01, 2007, 12:29:00 pm »
Since Nitewalker's not on here anymore, I'll say it: just buy a router - they're awesome!  :)
