Author Topic: Is This Possible With MaLa Plugin - LEDBlinky ??  (Read 7246 times)
lettuce
  • Make It So!
« on: July 27, 2007, 07:05:43 pm »
My Player start buttons are square Illuminated buttons, Is it possible to setup LEDBlinky so that when a credit has been added the player start buttons flash??
headkaze
  • 0x2b|~0x2b?
Re: Is This Possible With MaLa Plugin - LEDBlinky ??
« Reply #1 on: July 27, 2007, 07:16:26 pm »
I believe Arzoo did mention that he will add mame.dll support eventually which will mean games that have outputs  (like flashing start buttons when you insert a coin) will work with the LEDWiz.
The Mame output system is the only way to know when a credit has been inserted (apart from some global key hook of some sort). Even then there is no 100% way to know if Mame accepted the coin or if there is really a credit after pressing the coin button.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: July 28, 2007, 07:38:37 am »
It's definitely on my LEDBlinky to-do list.  :)
Robots will kill you.
Arcade Addiction
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: July 28, 2007, 08:24:57 am »
AtomicFE can already do that.  It can play animated sequence you defined when a credit is inserted in the game.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #4 on: July 28, 2007, 09:44:28 am »
Hey Youki. Why do you always hijack threads to promote your FE?
youki
    • Atomic Front End
« Reply #5 on: July 28, 2007, 10:31:54 am »
He ask for a feature that seems to  not be yet available in your FE.
So if he can not wait to see that implemented in your FE , he can use Atomic meanwhile...
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #6 on: July 28, 2007, 07:42:06 pm »
C'mon Youki. We both know he is not going to do that.  ::)
You have been 'crossing the line recently'. He didn't ask what Fe's could do it. If you were genuine you would also mention gameEX can do it etc...  ;)
[sarcastic] If you want to get it out of your system why don't you start you 'own thread' like What Atomic can do that MaLa can't. [/sarcastic]
We don't invade Atomic posts unless the user is looking for alternatives :angel:  (well not for a long time anyway)
My reaction has not come out of the blue, I was just hoping that you would get over it.
Play nice  ;)  ;D
youki
    • Atomic Front End
« Reply #7 on: July 29, 2007, 01:14:52 pm »
Because the list would be too long!  ;D
PsychoAU
  • Last login:October 04, 2020, 12:27:19 am
« Reply #8 on: July 29, 2007, 07:21:49 pm »
Wow, I think I'm gonna stop using AtomicFE now that I know what kind of jerk the creator is...
youki
    • Atomic Front End
« Reply #9 on: July 30, 2007, 03:26:57 am »
It was just a sarcastic stupid answer to a sarcastic stupid question.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #10 on: July 30, 2007, 08:54:40 am »
<snip>.... sarcastic stupid question.
Sarcastic question?  Obviously.
Stupid?  No.
lettuce
  • Make It So!
« Reply #11 on: July 30, 2007, 10:27:02 am »
Sorry guys didnt mean to start of an argument  :angel: .  So how long will we be talking for this to be implimented into MaLa, within the next release?
Green Giant
« Reply #12 on: July 30, 2007, 11:25:22 am »
It is all really dependent on a coder updating a plugin to do this.  The current mala version should be able to handle it, but someone needs to make a plugin to send the event.
Arzoo - Would it be possible/easier to just flash a designated button whenever the coin button is pressed?  Seems easier than having to read information from mame although you wouldn't know for sure if the game recognized the coin input.
Toxic Arcade, my first build
arzoo
    • LEDBlinky
« Reply #13 on: August 02, 2007, 10:12:48 pm »
Been away for a week.
I guess we could light the player start button after the credit button is pressed. Then I'd have to keep track of how many credits were added and how many times the start button was pressed to know when to unlight the button. But that's really a hack because it doesn't take into account multiple credit games. Obviously the best solution would be to let mame report back when the start button should be lit. I was hoping this was something mame hooker could handle - I'll need to look into that.
Arcade Addiction
lettuce
  • Make It So!
« Reply #14 on: August 05, 2007, 02:15:33 pm »
Cool, ill look forward to your progress on this
headkaze
  • 0x2b|~0x2b?
« Reply #15 on: August 05, 2007, 10:52:42 pm »
Don't get Mame Hooker confused with the MameInterop SDK. All you need is the latter to communicate with Mame. It provides a mame.dll and source code examples (including Delphi) to use it. Mame Hooker is Howards project that uses the MameInterop SDK to provide interfaces with hardware devices. Since your plugin already has everything needed to communicate with the LEDWiz all you need is mame.dll.
You can download it from here.
arzoo
    • LEDBlinky
« Reply #16 on: August 06, 2007, 12:10:43 pm »
hk - thanks for the clarification and link!  ;D
Arcade Addiction
