Author Topic: Jakks TV games question  (Read 2385 times)
IG-88
« on: July 21, 2007, 11:14:40 pm »
Does anyone know of a cheap way to get these to run on a PC monitor? There has to be a way to get it done without costing a bunch. I'm thinking you have to have a TV tuner right? How can you get the RCA connections/signals converted to VGA otherwise?
-HarumaN
RandyT
  • Last login:September 13, 2025, 08:12:16 am
    • GroovyGameGear.com
Re: Jakks TV games question
« Reply #1 on: July 21, 2007, 11:19:29 pm »
I guess it depends on what you mean by cheap.  Upscalers usually run about $40 - $60 depending on the quality you need.
It would probably be just about as cheap to buy a new 13" color set at Wal-Mart to use with it, or rescue a TV about to be dumped by someone who's upgrading to HD.
RandyT
miles2912
« Reply #2 on: July 21, 2007, 11:36:57 pm »
Cheap used tv's are all over craigslist.
IG-88
« Reply #3 on: July 22, 2007, 03:10:24 am »
RandyT
I guess by cheap I was guessing between the 10 - 20 dollar range. As for new 13" TV's they are becoming kinda scarce at my WalMart and Craigslist isn't much help to me either. Besides, I got all these damn 15" PC monitors to get rid of......
-HarumaN
« Reply #4 on: July 23, 2007, 01:06:58 pm »
to me there'd be no point in a hardware solution via PC because you could just play MAME instead. upscalers are the only other choice besides snaggin up an el cheapo used TV
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
« Reply #5 on: July 23, 2007, 02:13:23 pm »
I am using a Viewsonic VB50 at work for TV/Svideo/Composite to LCD...
Link
« Last Edit: July 25, 2007, 02:14:11 pm by Peale »
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #6 on: July 23, 2007, 02:36:29 pm »
I remember those.  they were very expensive back in the day.
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« Reply #7 on: July 23, 2007, 10:58:20 pm »
Link
Here ya go - $20 TV capture card with A/V and S-Video in (you'll need an adapter to change the audio part of the cable to a miniplug)
« Last Edit: July 25, 2007, 02:14:33 pm by Peale »
RandyT
« Reply #8 on: July 24, 2007, 01:16:37 am »
While a capture card would work, it would probably be redundant going through a PC ;)
RandyT
IG-88
« Reply #9 on: July 24, 2007, 07:01:10 am »
Ya, Randy is right. I don't want to go through a PC. If I wanted to do that I'd Mame it. I just wanted to figure out how to use these VGA monitors with those plug & play things.
I've been thinking. Do VCR's have TV tuners in them? With the right connections that may be an option. Or maybe using old satellite boxes.
-HarumaN
DarkBubble
« Reply #10 on: July 24, 2007, 10:39:42 am »
VCRs have TV tuners, but you're still left needing a VGA box.
Encryptor
  • Trade Count: (+34)
« Reply #11 on: July 24, 2007, 09:58:04 pm »
Couldn't you use something along these lines if not this exact one. From the description it sounds like it would work.
http://tinyurl.com/2wosaq
Encryptor
IG-88
« Reply #12 on: July 24, 2007, 10:33:12 pm »
I'm not sure but I don't think so. 1, I'd have to change the ends to females (do-able with adapters I suppose) and 2, I don't think the jakks devices put out a signal that a vga monitor can use, thus the need for a TV tuner.
-HarumaN
