Author Topic: T-Molding Slot Width  (Read 2016 times)
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
« on: April 24, 2003, 03:30:18 am »
I am trying to determine the width of cut required for t-molding so I can buy a cutter locally.
The slot cutter on T-Molding.com has a kerf of of 0.075". Is the kerf the depth of cut or width? and how much is 0.075" in metric? I've tried to convert to metric but work out that 0.075" is about the thickness of a piece of paper!
Help!!
VMJ Team
  • Last login:July 09, 2007, 09:29:50 am
    • Virtual Music Jukebox
Re:T-Molding Slot Width
« Reply #1 on: April 24, 2003, 08:58:19 am »
The cutter is most likely 1/2" deep...the 0.075 is the width(thickness) of the cutting blades...so 0.075" x 25.4 (mm conversion) = 1.905 mm
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #2 on: April 24, 2003, 05:55:47 pm »
1/16 is the width.  you can convert that to metric.
BobA
  • What Me Worry?
« Reply #3 on: April 24, 2003, 06:06:30 pm »
Sorry I am a bit confused.
If 1/16 is the size then it equals .0625 inch
.075 is not equal to 1/16.
Which one is right?
BobA
CitznFish
« Reply #4 on: April 24, 2003, 06:42:57 pm »
1/16 slot cutter bit is what's used for T-Molding.
http://www.coastaltool.com/cgi-bin/SoftCart.exe/a/ab/aman/slotting.htm?L+coastest+dkxv1470ff213621#cart
first item listed
there are other online suppliers as well
