Author Topic: 20ez Mating Video Connector  (Read 3025 times)
2600
« on: July 12, 2007, 02:51:48 pm »
Just got one of these in (Thanks leapinview) to use for testing.
Anyone know the mating connector for the Sanyo 20EZ video-connector?
Kevin Mullins
    • Me on Myspace
Re: 20ez Mating Video Connector
« Reply #1 on: July 13, 2007, 02:05:37 am »
mating connector ?
Not sure exactly where you mean by this......
Are you using the inverter board or not?
Will you be running a Nintendo game?
A typical installation would have a video signal cable going into the inverter board and then from there a ribbon type cable to the main chassis. (same connector on either cable)
Like so: http://www.mikesarcade.com/cgi-bin/store.pl?sku=MONCBLNIN
2600
« Reply #2 on: July 13, 2007, 08:28:35 am »
This is why I really am not good at talking on the forums, I can never word anything correctly.
On the Monitor PCB there is a 6 pin connector for RGB, Sync, and GND.  If you want to use the monitor, you have to plug a cable into this 6 pin connector.  The cable will have a connector on it that "mates" with the connector on the monitor PCB.
I didn't get a chance to look at it last night, but IIRC it looks like a .100 pitch connector.  Once I lookup and order the correct connector, I'll post the info for future reference.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 13, 2007, 12:13:38 pm »
Here's what you're looking for from Mouser Electronics (www.mouser.com):
# 538-22-01-3067 Molex KK .100" crimp terminal housing only
# 538-08-50-0114 Molex KK .100" crimp pins (needed for above to insert in the housing)
Remove the "538-" to get the actual Molex part number. You can also buy these from Bob Roberts.
2600
« Reply #4 on: July 13, 2007, 01:35:55 pm »
Thanks Ken.  Making a few other cables and wanted to get this in with my order.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: July 13, 2007, 02:38:24 pm »
My next step would have been Bob Roberts..... but Kens the man with all them fandangled part numbers and such.  ;D
