Author Topic: Introduction and small questions  (Read 1751 times)
angelomcm
  • Last login:August 02, 2012, 09:06:52 am
« on: July 11, 2007, 03:30:43 pm »
Good day.
This is my first ever post on this board, I am Angelo, I greet you all :)
I have been involved with arcade playing since the 80s and
finally got the chance to discover the world of DIY arcade
when I got my hands on an old, damaged Cruisin' Usa
cabinet (monitorless) and half a dozen of old control panels.
My attempts to revive it has been successfull this far, however, two things
bother me slightly.  :dizzy:
1) I have the full steering wheel system + force feedback device
attached,  is it possible to have it used in mame with a certain
(commercial) adaptor ?
2) I have dozens of button switches like in the picture added, are there
still compatible buttons to be found for it ?
stats of the switch:  inner hole diameter: 1cm / 0.39 inch
overall length 7.5cm / 3 inch
Are they even still sold ?
That'll do for now, I will soon add my project to the forum announcements.
Thank you all.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Introduction and small questions
« Reply #1 on: July 11, 2007, 03:43:24 pm »
Hi there.  For starters, I'm not 100% sure on the force feedback, maybe someone else can chime in.  The unit you have there at the bottom is called a leaf switch.  You can get stuff for those, but it's usually tougher to find since everything is a microswitch now.
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #2 on: July 11, 2007, 04:09:50 pm »
Welcome!
There are a bunch of vendors who sell leaf switch buttons, check the Vendors section of the wiki.
ArcadeShop, Mike's Arcade, Bob Roberts, LizardLick and Centsible all come to mind.
Working: Not Enough
Projects: Too Many
Progress: None
shardian
« Reply #3 on: July 11, 2007, 04:12:31 pm »
That is a sit-down model. Do you have the seat part?
And no, you can't interface your cruisin usa force feedback with MAME. Maybe some day though (I like optimism  ;D)!
angelomcm
« Reply #4 on: July 11, 2007, 04:44:18 pm »
Thanks for your replies.  I guess the steering wheel panel is useless then, maybe
i can salvage the speakers inside it though.  Too bad, the gearstick and
wheel seemed cool  ;)
In all case, it does indeed resemble a leafswitch like on the picture on the wiki
(which i thought i read through, tsk tsk me... sorry..).  Now to order the needed
buttons !
Thanks for the help !
angelomcm
« Reply #5 on: July 11, 2007, 04:45:48 pm »
Unfortunately not, it will be a sweet bench-model once i visit the IKEA store in Belgium
somewhere ;)
lanman31337
« Reply #6 on: July 11, 2007, 04:51:51 pm »
You could use the shifter and steering wheel in mame though :)
shardian
« Reply #7 on: July 11, 2007, 04:54:50 pm »
buttons !
You can use the controls in MAME, you just can't interface the force-feedback system.
Do a search on "dual strike steering hack" to find a way to use the wheel...or get an A-Pac from Ultimarc.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #8 on: July 11, 2007, 05:21:31 pm »
I wonder if this usb interface from happ would provide forcefeed back with the optional daughter card?
http://www.happcontrols.com/images/pdf/ins-0037.pdf
I'm just throwing this out there I don't know if it will work or not.  On page 2 it makes mention of output for lights and solenoids.  Hopefully someone who knows a lot more about this than me can chime in an say if this will work for force feedback.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
angelomcm
« Reply #9 on: July 12, 2007, 12:53:43 am »
Thanks again for the helpfull replies.
Hmm, the force feedback has a low priority now that I hear that
the wheel and gears CAN be hooked up somehow.
After work, I will take a look at the cables going from both devices
and compare it with the A-pac.  Too bad the pedals dont work no more,
but I guess that is a challenge on its own...  :laugh:
shardian
« Reply #10 on: July 12, 2007, 09:19:38 am »
If you are a wiz programmer that can find a way to interface with the thoroughly buried code for force feedback in MAME, knock yourself out. ;D I am waiting to see what cool things people can do with that driver board, it could be really neat!
