Author Topic: coin mechanism  (Read 4576 times)
dannyyy
  • Last login:July 19, 2007, 07:37:05 pm
coin mechanism
« on: June 24, 2007, 10:39:00 am »
I bought myself a S.E.C.I. RM4 coin mechanism on ebay. It was a bargain so I thought to make a good deal.
Problem now is, that I can't find documentation on the thing and I don't know how to make it work.
I want to put it in my mame cabinet that I'm working on but I don't know if its possible to connect the RM4 to my computer.
anyone knows how to do this?
thanks
Ken Layton
  • Guru
  • Technician
Re: coin mechanism
« Reply #1 on: June 24, 2007, 11:17:21 am »
I have no idea what you're talking about. A picture please of the object in question.
dannyyy
Re: coin mechanism
« Reply #2 on: July 08, 2007, 08:06:10 pm »
the mechanism is this one.
www.highway.net.au/img_parts/img_3985.jpg
does anyone have an idea how to wire it to a pc to use in mame?
Green Giant
Re: coin mechanism
« Reply #3 on: July 08, 2007, 08:16:52 pm »
It says to connect it, "Connects to the credit board through a 10 pin cable."  Doubt anyone on here can connect it.  No simple switches.  You will have to read a signal from the board.  If you have access to a potentiometer, you could hook it up and try and read the signals out of the mech.
Toxic Arcade, my first build
HighNoon
  • Last login:December 08, 2023, 08:21:37 am
Re: coin mechanism
« Reply #4 on: July 08, 2007, 11:36:42 pm »
Do you mean a multi-meter?
Not trying to be rude, you might know some cool way of reading voltages I don't.  ;)
superbigjay
  • Last login:October 22, 2023, 02:50:03 pm
  • I'll always be a kid...
    • superbigjay website
Re: coin mechanism
« Reply #5 on: July 09, 2007, 12:43:33 am »
hello dannyyy.
I've found this pdf.
www.alca-coin.com/files/05%20R6.1%20eng.pdf
That coin mech is programmable and very flexible.  But it will be difficult to hook up...
It can accept different coin/token and you can assign a value to each of them.
The thing is that it;s using its 10 pins connector and some sort of serial encoding to
inform the "money board" what value was inserted...
goodluck,
Jay
superbigjay
Re: coin mechanism
« Reply #6 on: July 09, 2007, 12:50:17 am »
this is the same website with all the products they support...
http://alca-coin.com/eng/index25dc0.html?p=pro&n1=menu
this is probably the pdf that has the validator info:
http://alca-coin.com/files/05%20R6.1%20eng.pdf
have fun...
 >:D
MonMotha
Re: coin mechanism
« Reply #7 on: July 09, 2007, 01:12:22 am »
The manual claims that there is a 4 pin connector at RS-232 levels.  This could be hooked up to a standard PC serial port with a suitable (possibly custom-made) cable.  Documentation for the protocol it speaks is supposedly on their website, but I have not looked.  They seem to call this "master mode".
Once you have it hooked to your serial port, you would then simply run a program in the background to monitor the serial port for the coin device to speak and take appropriate action (such as artificially generating a keypress) when it does so.  This would be much easier than using the other interface on there.
If you don't have a serial port, one of the USB to RS-232 serial adapters should work for this purpose as it appears to actually be sending serial data, not bit-banging the handshaking lines.
« Last Edit: July 09, 2007, 01:15:26 am by MonMotha »
Green Giant
Re: coin mechanism
« Reply #8 on: July 09, 2007, 09:34:54 am »
Oops, wasn't thinking of a meter at all.  Had a brain fart there.  What I meant to say was an oscilloscope.  Figured this coin mech might send varying signals that could be read by an oscope.  Out of school for a little while and you start forgetting everything.
dannyyy
Re: coin mechanism
« Reply #9 on: July 11, 2007, 01:46:32 pm »
thanks for the replies. I'll try to figure out what the easiest option is for me.
If I can get it to work, I'll let you know.
greets,
Dannyyy
