November 21, 2009, 08:53:54 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: 1 ... 41 42 [43]   Go Down
  Send this topic  |  Print
Author Topic: Soft-15KHz - slim new tool for 15KHz on normal vga cards  (Read 110824 times)
Ummon
Trade Count: (+12)
Full Member
Offline Offline
View Profile
« Reply #1680 on: October 30, 2009, 03:32:06 PM »
Has anyone noticed a slugishness in trackball games (specifically Centipede and Millipede) after installing this awesome utility?  I'm not sure if it's related, but now there is a slight delay from when I physically move the trackball and when my player moves.
Running at different resolutions can cause frame rate glitches. How MAME runs natively (and as I've said before, this seems to be getting worse as MAME develops) can affect this.
As well, how your monitor interacts with MAME is a factor. Analog monitors I've used, as long as you're giving good and correct signal wiring-wise, and you're within operational range signal-wise, have been smoooooth with regular MAME. Older MAME, anyways.
My digital multi-sync, on the other hand, is a little finicky at times, cos it has specific modes of its own. (Another reason I stick with AdvanceMAME is that it runs the best in this case.)
Logged
Yo. Chocolate.
Stephen Hawking
Antropus
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #1681 on: November 02, 2009, 02:03:20 PM »
SailorSat, any news about the windows7 situation?
Is there anyone using it successfully with the final version of win7?
Thanks,
-Kris
Logged
kronic24601
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1682 on: November 05, 2009, 11:01:25 AM »
Thanks,
-Kris
This is also something I would also like to know. I have Windows 7 64 Bit, and there is a XP compatibility mode ... I'm not sure if that would be usefull though in this application.
Logged
SailorSat
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1683 on: November 05, 2009, 12:13:19 PM »
Sorry for the time being Smiley
Currently I'm a little frustrated about reallife stuff =)
Lookin for a new job and desperately searching for some stuff I did showing what I can... And MAME hacks and that stuff sure doesn't help.
Ever tried to "show" someone how soft15khz works without a 15khz capable display? ^^
Geez...
As for Windows7; the compatiblity mode won't help.
For some reason I think the last time I tried it only worked with NVidia cards as the ATI cards won't show up any lowres modes for some unknown reason.
However I can't look into it at the moment.
Logged
I do all that stuff even without a Joystick Wink
Soft-15kHz, cabMAME
Antropus
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #1684 on: November 05, 2009, 02:14:30 PM »
Sorry to hear about that. Best of luck finding a great new job!
Cheers,
-Kris
edit: oooops... I didn't know ;-)
« Last Edit: November 05, 2009, 06:16:17 PM by Antropus » Logged
Ummon
Trade Count: (+12)
Full Member
Offline Offline
View Profile
« Reply #1685 on: November 05, 2009, 04:32:38 PM »
Sorry to hear about that man.
Edited for accuracy.
Logged
Yo. Chocolate.
Stephen Hawking
FrizzleFried
no one listens to me anyway.
Wiki Master
Trade Count: (+4)
Full Member
Offline Offline
View Profile WWW
« Reply #1686 on: November 07, 2009, 02:09:49 AM »
Does soft 15khz support multiple monitor setups?
Logged
SailorSat
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1687 on: November 07, 2009, 04:26:36 AM »
Basicaly it does.
It DOES support INDEPENTEND settings if you have multiple graphic cards.
As for single card solutions... well... currently all settings are applied to "all heads" of a graphic card.
If you want to drive two arcade screens with one or two cards, it works fine.
If you want to drive one arcade and one vga screen, you will need to use two cards.
« Last Edit: November 07, 2009, 04:28:26 AM by SailorSat » Logged
Soft-15kHz, cabMAME
FrizzleFried
Wiki Master
Trade Count: (+4)
Full Member
Offline Offline
View Profile WWW
« Reply #1688 on: November 07, 2009, 01:23:09 PM »
Basicaly it does.
Kick ass!  I've picked up a Punch Out cab that has been JAMMAtized.   I am debating whether to restore to Punch Out or to make it a dedicated Multi Punch Out MAME cab.   I think Punch Out,  Super Punch Out,  and Arm Wrestling as well as PC-10 stuff would be pretty cool to have running in this cab.
Since I have to use a JPAC,  I guess I'd use the JPAC for the arcade controls and the lower monitor,  then just run a break out cable to the 2nd monitor from the 2nd header...right?
Logged
SailorSat
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1689 on: November 07, 2009, 01:49:49 PM »
Nice one Wink
That should work fine Smiley
Had a pair of Racing-Cabs wired to one PC for OutRunners Dual-Action Smiley
Logged
Soft-15kHz, cabMAME
Ummon
Trade Count: (+12)
Full Member
Offline Offline
View Profile
« Reply #1690 on: November 07, 2009, 04:14:01 PM »
Soft15 has for a long time apparently registered both heads, though. I was under the impression they were independently configurable - but then, why would it matter, if you can set independent resolutions via your drivers?
Logged
Yo. Chocolate.
Stephen Hawking
claypool
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1691 on: November 14, 2009, 09:32:58 PM »
Just started testing this program and have run into problems already
I install the nvidia drivers for my 6800 GS then use the tool quickres to select 640 x 480, then I install soft15khz and reboot
it works fine on my arcade monitor I can see windows after a reboot then when I uninstall the soft15khz and reboot it gets locked in 15khz mode
why does it do this shouldnt it reset to normal when I uninstall?
I have a monitor switch so i can easily change between PC monitor and arcade monitor.
thanks
Logged
tisurame
Trade Count: (0)
Full Member
Offline Offline
I'm a llama!
View Profile
« Reply #1692 on: November 17, 2009, 10:15:00 AM »
I'm using a Geforce 9400gt (with the latest drivers) and 640x480 interlaced at 15khz is not working. Is this a know problem?
Logged
speedklz
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1693 on: November 18, 2009, 04:09:00 PM »
Well I run into sompthing odd the other night.. I had a problem with some registry corruption on a machine I was cab testing well when It would boot it was showing the boot screen in split mode and the windows startup screen also, but after fixing the registry it went back to the way it always is , that you cant read anything till windows load the soft15k stuff... Is this weird or what?  It almost looked like when it devides the 30khz into the 15khz on jpac.
Logged
Best of the Best of the Best. Sir!
Pages: 1 ... 41 42 [43]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.241 seconds with 29 queries.
