Author Topic: Someone reccomend me a place in the USA to fix a Sharp 33" KTM-F33 chassis  (Read 3251 times)
Frankiebonez
  • Last login:June 11, 2007, 04:57:42 am
Like the above states.  I want to send the chassis out to have it benched and freshened up.  Anywhere in the USA would be ideal, Zax amusements works on them apparently but I really would like to avoid shipping to Austrailia.
Thanks for any help!
Ken Layton
  • Guru
  • Technician
That's a Kortek chassis. www.casinotech.com is the authorized Kortek repair center.
shorthair
And since you now know the manufacturer, there might be more than one service center, and perhaps one closer than another.
Kevin Mullins
    • Me on Myspace
There's also individuals like Chad Entringer that works on monitors as a service....
http://www.arcadecup.com/
Frankiebonez
I tried Chad but unfortunately he doesnt work on this model of chassis :(
Frankiebonez
Is Kortek a Sharp brand?  Whats the difference between Sharp and Kortek or are they the same?  Sorry just a bit confused and curious.
Ken Layton
  • Guru
  • Technician
Kortek made monitors for several companies. Sharp Image used both Kortek (primarily) and Sony as their monitor suppliers.
Kortek would rebrand/relabel monitors for a particular customer. The "KT" (or in your case "KTM") indicates a Kortek model number.
Happ Controls repairs all makes/models of arcade & gambling video monitors at their monitor repair shop in Las Vegas. Casino Tech is also in Nevada.
There's another Kortek repair shop at http://gamingstuff.com/displays.asp
Frankiebonez
OK cool :)  I noticed that KT in front of the name, and that also Kortek had the same first 2 letters in all there model numbers.  I'll contact these locations see if I can get anywhere... thanks alot!
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Not sure how you are makng out??
As far as repair goes, we shy away from a number of breeds "Kortek" and "Neotec" on the top of the list..
If you get desperate, we have recently supplied 3 0r 4 customers with replacement boards for 32/34" Sharp monitors.
But first you must be very confident your tube and yoke is good.
If so look on the tube and yoke for part #'s  as well as manufacturer.
Tube numbers will start with A79 or A80- if you can give me a manufacturer.
Yoke numbers - if Thompsom 79L....
I will cut it short here in case you have already repaired your board.
In any case good luck
Rick Nieman
Nieman Video Displays
www.niemandisplays.com
Rick@niemandisplays.com
519-621-1722
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Domolover
  • Last login:October 26, 2011, 10:19:52 pm
I also have this arcade monitor ktm-f33, do i need the AC isolation for  this monitor?
thanks guys for your help !
