Author Topic: Question Regarding Wiki (kinda off topic not this wiki)  (Read 6062 times)
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« on: April 25, 2007, 10:06:29 pm »
I thought I'd post this here to see if anyone familar with Wiki editing knew the answer.
We have a wiki at work that I am trying to do something with. Its based off the wiki from http://www.mediawiki.org/wiki/MediaWiki if it matters. This is what I am trying to do. We have a public drive on our computer that I have certain support documents housed. I would to be able to create an article and place a link in it that would direct your or even better open the document on the public drive. For instance I have some documentation I've done that is in word or pdf and I would like to say click on the link to access this document. I can't see to figure out how to get a hyperlink to do this with a local file. I can do it with a http: address though.
Anyone have any ideas?
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:October 17, 2025, 07:04:22 am
Re: Question Regarding Wiki (kinda off topic not this wiki)
« Reply #1 on: April 25, 2007, 10:26:37 pm »
Try formatting a link something like this:
file://///<servername>/<directory>/<filename>
For instance, a file named "bookmarks.html" in the "John" folder in the "Backup" shared folder on the "Server" server would look like:
file://///Server/Backup/John/bookmarks.html
You can try to get the exact syntax by using your web browser, going File-Open, browsing your network to the server/folder, opening the file in question, and then copying the link.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
stephenp1983
« Reply #2 on: April 26, 2007, 03:15:36 pm »
Thanks Saint I'll try this and let you know.
stephenp1983
« Reply #3 on: April 26, 2007, 03:26:33 pm »
Well I tried it several different ways to no luck.  Here is how it is formated when I browse for it.  When I edit the wiki article it shows exactly what I put, but not in hyperlink form.:
file:///P:/support/Internal%20Support/Transfering%20Putty%20Settings.pdf
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« Reply #4 on: May 08, 2007, 08:52:29 am »
You should try to add [ ] to it. A [[documentname]] syntax is a wikilink to connect wikidocuments, a [hyperlink] syntax is used for hyperlinks. The square brackets tell the Wiki software to convert that section of text to a hyperlink.
