Author Topic: How big is your cabinet?  (Read 2148 times)
Craig Pilecky
  • Last login:April 15, 2003, 02:47:32 am
« on: April 15, 2003, 04:34:53 am »
Im just curious how big most of you have built your cabinets. Im betting that mine is one of the largest. But to accomodate a 27" TV it had to be pretty large. I assembled it in the room that its in, but if I have to I can get it through the door if I unbolt the control panel.
Height: 72.5"
Width: 28.5"
Depth: (at base 38") (at control panel 44.5")
« Last Edit: April 15, 2003, 04:37:14 am by Craig Pilecky »
paigeoliver
  • Awesome face!
Re:How big is your cabinet?
« Reply #1 on: April 15, 2003, 04:59:24 am »
22" Wide and 26" deep at the control panel, and 61" tall (Artic Mini cab).
I am not really into really big cabinets, as it is hard to follow all the action on a large screen. Like those new 25" monitor Ms Pac/Galaga machines. I gotta kind of stand back from the thing to see the whole screen. I prefer the 19" monitor ones. If you really want some high scores, try a cocktail, or mini of some kind that uses a 13" monitor. Very easy to see everything at once.
cdbrown
  • Bowowow
« Reply #2 on: April 15, 2003, 05:00:11 am »
My current design has the
Height: 198cm (78")
Width: 85cm (33.5") (cabinet only - 4-p panel is much wider)
Depth: 105cm (41.3") (125cm or 49.2" with panel)
Height and depth may change slightly depending on placement of 27"TV.  Based on a Midway type cab.  This has to go through the sliding door out the back.  The height may drop if I decrease the space above the tv, but this would cause the tv the be angled more (keeping roughly perpendicular with my eye level) causing it to be slightly deeper.  I think I might need someone to look over my design to make sure I have the measurements and angles right.
Cheers
-cdbrown
Vampyre
  • Last login:April 14, 2004, 09:19:47 am
  • Roger Roger!
« Reply #3 on: April 15, 2003, 05:58:39 am »
Mines
70" Tall
32" Deep
25" Wide (37" with CP on)
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #4 on: April 15, 2003, 10:11:56 am »
Hmmm..  can't remember specific mesurements..
about:
70 somthing inches tall
27" wide
30 something inch cp
Now with cup beer holders!
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #5 on: April 15, 2003, 10:15:49 am »
the standard Centari cabinet is a hair under 25.5" wide for a 19" vertical monitor.
I don't remember the other dimensions.
Bob
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #6 on: April 15, 2003, 01:00:41 pm »
measurements are all on my stie:)
Anyway
25" wide x 73" high x 38" deep
Size wise it is based off my double dragon II cabinet.  It's a little deeper than the ddragon2 cabinet.
unclet
« Reply #7 on: April 15, 2003, 08:31:46 pm »
Without the control panel attached the measurements are:
     75"height x 28-1/2"width x 43"depth
My control panel measurements are:
     7"(front) to 9"(back) sloping height x 57"width x 19"depth
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #8 on: April 15, 2003, 09:41:12 pm »
my cab is
38" deep
 29"wide
~72" tall
